The manual says it has a MT3 taper and mentions undoing the drawbar in the instructions.http://www.topmaq.co.nz/images/item_manuals/MEMI1200-MAN1.pdf
Quote from: Arbalest on September 01, 2014, 11:20:25 AMThe manual says it has a MT3 taper and mentions undoing the drawbar in the instructions.http://www.topmaq.co.nz/images/item_manuals/MEMI1200-MAN1.pdfThat could be worth looking at!John
The Sherline lathe I have has a brass bed! It is one of the early ones made in Australia.
Ally doesn't seem to be the right stuff for making a milling table. Mass and internal damping are your friends when machining, ally doesn't really have those properties.
Iron would have to be cast then machined. The ally table could be made from bar stock or even bought as an extrusion. Ally doesn't seem to be the right stuff for making a milling table. Mass and internal damping are your friends when machining, ally doesn't really have those properties.Rod
Yes, quite right. 99% of machine tools are made from cast iron and steel for it's strength, rigidity and damping. Extruded Aluminium Alloy is just cheaper to produce.
Nicolas, my brass Sherline lathe came from TradeMe and I have another brass Sherline bed from the same source but I have not headstock for it. Maybe I will make one!
Whilst I may be able to tolerate small cuts on CNC mill like your Sherline Tom, where the machine is effectively doing all the donkey work (once it's set up) I'd find it a whole lot more frustrating on a manual milling machine. Depending on the material I regularly take cuts several mm deep on my VMC and still sometimes wish I could take more. I've never checked the accuracy of my mill, only the parts produced on it and the only time they aren't up to spec is down to operator error! I suppose it's horses for courses, if you only want to make small stuff in relatively soft materials I guess a small lightweight machine is fine. Having said that most of the cheaper machines where I used to work that had extruded Aluminium work tables (bandsaw, router table, etc) were a lot noisier in operation than the older machines with cast iron tables.I procrastinated for a long time before buying my milling machine and very nearly bought an X3, the only reason I bought a VMC in the end was because I thought I'd prefer a knee mill (because that's all I'd ever used before) and I thought the X3 was far too light weight! Luckily for me I've never regretted my purchase, I just once in a while wish it was a bit bigger but I soon get over it! Perhaps folks say it too often, but you can make small stuff on a big machine but you can't make big stuff on a small one. Just a clever way I know of saying make sure you buy big enough! Only the OP can decide that one.
What *I* care about is the parallelness of the table to ways, the squareness of the axis, and the flatness and mating of the sliding and bearing surfaces of the machine, and so on. The static geometry, and its performance in tests with light cuts.
I plan on 99% brass and aluminum work, that's why I'm thinking the Taig or sherline would be good for me.
