Author Topic: 1/5 scale Chevelle  (Read 72721 times)
Offline lakc
  • Detroit, MI
Re: 1/5 scale Chevelle
« Reply #120 on: September 17, 2014, 12:25:53 PM »
Know someone with a Faro Steve?.....
http://www.faro.com/en-us/home
By a Revell 1/24th kit and scan the body and make a point cloud...and you'll have the 3D model.
Last time I was in Auburn Hills they were throwing one away. Thought about wheeling it out to my truck..... ;D
Come to think of it, I do know a guy with a Faro around here, ill make some inquiries. Tis looking very good Steve, red metals are so much fun to work with. :)
Jeff
« Reply #121 on: September 17, 2014, 01:02:45 PM »
We've got one at work, but I need to tread carefully regarding "G" jobs....
I'll make some "inquiries"    Dave
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #122 on: September 17, 2014, 09:15:51 PM »
Never heard of it. Looks cool.
« Reply #123 on: September 17, 2014, 09:17:29 PM »
Dave, Lakc, thanks for taking the time to ask.
« Reply #124 on: September 17, 2014, 09:48:59 PM »
Steve,
I was going to suggest adding a digitizing probe to your CNC mill to digitize a model. You use Mach3 I believe?  It appears there is a digitizing wizard for Mach3.
« Reply #125 on: September 18, 2014, 12:01:20 AM »
Thanks Tim. I might look into that. Resolution would have to be good as im going to scale up from a model.
I laid out all my brackets using the awesome CamBam. The mill drilled out the plate and then cut out all my pieces. These parts are made with 1/4 inch plate on a real car. I found 16 gauge brass at .051 thick. Close enough in my book.
The 4 link brackets are installed. I guess the next step will be to get the rearend housing done and then get the rear suspension sorted out.
« Reply #126 on: September 18, 2014, 12:33:22 AM »
What material was under the 16 ga. brass and how was the brass held?
« Reply #127 on: September 18, 2014, 12:36:19 AM »
More amazing parts Steve. How long did it take to cut all those out ?
« Reply #128 on: September 18, 2014, 12:49:19 AM »
Corian.
I had the CNC drill holes in the corian before screwing the plate down. Then when the drilling was done the holes were tapped and the individual pieces were held down with screws. Then the original screws were removed and the parts were cut out..
« Reply #129 on: September 18, 2014, 12:54:29 AM »
The program ran for 1:15 but if you figure in making the fixture and pre-drilling for the screws and tapping them it was probably right around 2 hours.
« Reply #130 on: September 18, 2014, 12:59:56 AM »
Not bad at all Steve...just imagine the time it would have taken to do all of those manually!!
« Reply #131 on: September 18, 2014, 01:09:29 AM »
 8) :ThumbsUp:
« Reply #132 on: September 18, 2014, 01:20:49 AM »
Yeah!  Would have been faster to build a CNC mill.
Working on the housing for the rearend. Might start cutting this weekend.
« Reply #133 on: September 18, 2014, 01:07:18 PM »
This thread started while I was traveling, but just caught up today.  Heck of a project!   :ThumbsUp:
Offline Mosey
  • Rosemont, New Jersey, USA
« Reply #134 on: September 18, 2014, 01:59:26 PM »
Steve,
Are you going build a 5 speed transmission also? (I gotta see this!)
Mosey  :naughty: :naughty:
