The Grizzly G4002 is a much better value for $1500.00 more than the G4000. The problem with all Chinese machines such as this is their very poor quality control. It is advisable to inspect the entire machine mechanically & electrically before operation. Things such as lose wire connections, lose screws & sloppy made mechanical things will need to be corrected, but it does come with tool room features.
Features:
Removable gap bed allows turnings up to 17" in diameter
Nine spindle speeds - ranging from 70 to 1400 RPM
Easy-to-use lever controls
Hardened and ground cast iron bed
Cuts 4-112 Standard TPI and 0.2-4.5 Metric
Full length splash guard
On/off/reverse switch on carriage
Standard Equipment:
6" 3-jaw chuck with two sets of jaws
8" 4-jaw chuck with reversible jaws
Steady rest
Follow rest
10" faceplate
Toolbox
Quick change tool post with one tool holder
1 Dead center: MT#3
1 Live Center: MT#3
Set of six change gears
1/2" chuck w/ MT#3 arbor
Specifications:
Swing over bed: 12"
Swing over gap: 17"
Swing over cross slide: 7"
Distance between centers: 24"
Bed width: 7-1/4"
Spindle bore: 1-7/16"
Taper of spindle bore: MT#5
Spindle: Camlock D1-4
Cross slide travel: 6-1/4"
Compound travel: 3-1/4"
Tailstock barrel taper: MT#3
Tailstock barrel travel: 4"
Diameter of tailstock barrel: 1-9/16"
Number of speeds: 9
Range of speeds: 70, 200, 220, 270, 360, 600, 800, 1000, 1400 RPM
Motor: 2 HP, single-phase, 220 Volt, 12 amps, 60 Hz, 1725 RPM
Height w/o stand: 23"
Height w/ stand: 52"
Length w/ stand: 53"
Width of stand: 26"
Approx. shipping weight: 1004 lbs.
Jim Allen
