Hi,
You know how it is?? just when you're ready to start another niggle had to be put right
This little drill attachment has driven me up the wall for a while as you don't know how deep you've gone so some graduations were put onto the spindle.Just though I would mention it for any one making such a contraption
The main body is from 30mm brass with the power cylinders bore straight through, Well I couldn't get the old boring cutter to give a good finish shouldn't complain its lasted a long time.
So a bit of 1/4 stubs was set up in the three jaw with a 1/8 packer to throw it out
The end is filed as per Mr Thomas instructions and I only harden and temper the tip should a mishap occur the cutter bends and can simply be straightened up not that we have any mishaps
Just a few shots of the tool Iv found it very useful for over 20 years and the best bit it only costs a few coppers to make OK its no fancy bit of kit but this tight wads wont spend the pounds they ask and can the commercial ones bore down below 3mm and not cost an arm and a leg
Iv machined the body with a 1mm allowance all round as Im not sure where Im going with it yet
The same applies to the upright Im looking at Huibs video to see how he has changed a few things I want to incorporate into the toy.
The gears are next up Mr Ridders used some old clock gears on his built.There is a dimension between the displacer and the magnet that has to be adhered to so 40 teeth 0.5 mod gears have been made luckyfor me I had made a batch for a futur build when I find some info on the Cracker T
These gears just needed thinning down and have been held in a split ring to save damaging the teeth.I was going to mark them out for tapered spokes but decided life's to short and anyhow couldn't find my tin of pins for my marking out jig
they will be some where safe no doubt
A simple jig just to make sure the gears run absolutely free as drag will kill this little toy. I did round up the dimension by 1/2 a thou just to be sure
Next up the actual bearing housing and gears
Thats me up to date so thanks for looking and best wishes
frazer
