Author Topic: Heat Treatment Kiln  (Read 3552 times)
Offline tangler
  • Christchurch, UK
Heat Treatment Kiln
« on: April 10, 2014, 10:40:29 PM »
Now it may be because I spent all my working life as a (sort of) metallurgist but I have been feeling the need for a heat treatment kiln (furnace, muffle) call it what you will.  I've followed a few on ebay but finally plumped for this mostly because it has a PID controller, which most of the 2nd hand ones don't:
http://www.ebay.co.uk/itm/310922375462
It goes up to 1000C (1832F).  Temperature control is surprisingly good.  I had it up to 900C and then came down in 50C steps to try and anneal an iron casting with some hard spots.  Temp stabilised quickly at +/- 1 degree.  Should be fine for heat treating BeCu and hardening and tempering tool steel.  Turn it on its side and I reckon I could get a crucible of aluminium in there, big enough for casting pistons or aero engine bits.
I took some time to decide on this: the company are based in London, it's made in the UK (although I am sure many of the bits are imported) but it seems clear that English is not their native tongue.  Nevertheless, I am pleased with the kiln and they have some other interesting stuff on their web site.
Cheers,
Rod
Offline stevehuckss396
  • Sterling Heights, MI
Re: Heat Treatment Kiln
« Reply #1 on: April 10, 2014, 11:45:37 PM »
Thats pretty nice. Should come in real handy.
Offline Tjark
  • Woldendorp, Netherlands
« Reply #2 on: April 11, 2014, 08:37:17 AM »
This is a beauty.
Can you program it in time curves with a special temperature ?
This would be very handy for heath treatment off aluminum.
   Tjark.
« Reply #3 on: April 11, 2014, 08:50:03 AM »
Using that will keep the workshop warm  :LittleDevil:
Offline tangler
  • Christchurch, UK
« Reply #4 on: April 11, 2014, 09:10:11 AM »
This is a beauty.
   Tjark.
Sadly, no.  The ability to programme a ramp to control the cooling rate would be very useful.  None of the cheap PID controllers I've seen on eBay seem to have this function.
Rod
Offline Ramon
  • Suffolk in the UK
« Reply #5 on: April 11, 2014, 10:47:40 AM »
Very nice purchase Rod  :ThumbsUp: and a very useful addition to the shop.
I have a nice little oven too but a truly antiquated and 'Heath Robinson' controller - so much so that I've never had the courage to use it  ::)
Hardness tester next ?  ;)
Regards - Ramon
Offline tangler
  • Christchurch, UK
« Reply #6 on: April 11, 2014, 11:07:26 AM »
Weeeell, Dave Lammas did a hardness tester design in Model Engineer and the castings are available from Blackgates....... :facepalm2:
