Author Topic: My Virtual Engines  (Read 13143 times)
Offline ausdier
  • Burpengary, Australia.
Re: My Virtual Engines
« Reply #15 on: February 05, 2013, 04:19:51 PM »
I was pretty pumped when I finished this one............... :lolb:
Offline ausdier
« Reply #16 on: January 28, 2014, 12:26:30 PM »
This one might blow someone away.  ;D
There is also a 3D PDF file.
PatJ
« Reply #17 on: January 28, 2014, 02:37:14 PM »
Nice models Ausdier.
I am seeing more and more of the virtual engines online.
I don't have the render package, but here is the latest model I have worked on.
It is a work in progress, with the intent of casting this engine one day.
And a 3D pdf.
Pat J
Offline ausdier
« Reply #18 on: January 29, 2014, 02:46:45 AM »
That looks great Pat.  :ThumbsUp:
Good luck with the casting and hope to see a thread started soon.
Cheers.
Offline ausdier
« Reply #19 on: March 09, 2014, 04:20:15 PM »
Next one.  :)
BRASS STIRLING 60
Picture and 3D pdf.
Done in Inventor Pro 2012.
« Reply #20 on: March 09, 2014, 04:39:18 PM »
Just went through your thread.
Lovely models.
I've just started CAD and one thing I like is the ability to work/play even when I can't get into the shop.
Offline ausdier
« Reply #21 on: March 11, 2014, 11:47:26 AM »
Thanks Carl.
Good luck with your CAD as well, hope to see one of your models here soon.
I do most of my CAD work when I am sitting in front of the TV of an evening.
Cheers.
Offline ausdier
« Reply #22 on: April 03, 2014, 05:08:04 PM »
Here is a project some people might want to get off the ground.  :facepalm2: :lolb: :slap:
Some renders and another 3D PDF to have a look around.
Cheers.
Offline philjoe5
« Reply #23 on: April 03, 2014, 05:17:34 PM »
Good stuff Ausdier.  I owe you a hearty thanks for doing a virtual cylinder head for my Bonzer engine.  You got me to thinking outside the box and though I didn't use your design exactly it got me over one of the initial hurdles I was facing when I first considered making the Bonza.  Then that led to AussieJimG and well the rest is history.
Your models may be virtual now but they may lead someone to build one :ThumbsUp:
Cheers,
Phil
Offline ausdier
« Reply #24 on: April 04, 2014, 01:55:59 AM »
Thanks a lot for that Phil, I am truly glad that I was able to help in some small way.
Who knows, maybe one day when I get some room I might be able to make something like this for myself.
Cheers and keep up the good work.  :cheers:
Offline ausdier
« Reply #25 on: June 12, 2014, 05:19:54 PM »
Just realised that I hadn't posted this engine.
So this put a bit of a FIRE under me to post it.  :lolb: :hammerbash: :ROFL:
Offline PStechPaul
  • Cockeysville, MD 21030
« Reply #26 on: June 13, 2014, 08:17:08 AM »
Awesome models. It would be a real challenge to build some of those from metal and wood. I enjoy machining, especially learning new things, but I may be more of a "virtual model" person. I got about halfway through building a small engine that I modeled using TurboCAD 3-D, but as I made parts and assembled it I found how hard it is to hold tolerances and actually get something together and moving smoothly. And I see changes I might like to make, but more easily done on a virtual machine.  ;) :atcomputer:
Offline ausdier
« Reply #27 on: June 14, 2014, 12:56:23 PM »
Thanks a lot Paul.
I hope some day soon when I get a few bigger projects done I might be able to start something myself.
Offline ausdier
« Reply #28 on: August 29, 2015, 01:52:20 PM »
Here is a sterling idea.
A 10-inch Stirling Engine Powered Fan called Moriya.
Designed by Dr. James. R. Senft.
Drawn with Inventor Pro 2012.
Rendered with keyshot 5.
Also a 3D PDF.
« Reply #29 on: August 29, 2015, 04:37:45 PM »
Those are all amazing renders Darren. You do some beautiful work.
