Author Topic: Dodgy Hex Key  (Read 5085 times)
Offline Danny M2Z
Dodgy Hex Key
« on: September 17, 2013, 02:09:08 AM »
G'day.
I found a set of long T handled metric hex-keys at a well known Australian hardware store.
Just what I needed for fiddly screws as they had a ball end. Now at the price I did not expect fantastic quality, but I did expect them to fit a socket head screw.
The first screw I needed to tighten had a 4mm socket, but the key just spun in the hole.
Out with the measuring gear. Oop's, somebody at the factory in China must have a red face!
* Danny M *
Measure twice - cut once. You can't put it back!
Offline tel
  • Bathurst District, NSW, Oz.
Re: Dodgy Hex Key
« Reply #1 on: September 17, 2013, 04:02:02 AM »
Yeah, you do need to check stuff from Mr. B's Emporium - mostly OK, but now and then .....
Offline sshire
    • LS Editions
Re: Dodgy Hex Key
« Reply #2 on: September 17, 2013, 04:49:25 AM »
It's correct. Their tolerance is +- 2mm.
Best,
Stan
Re: Dodgy Hex Key
« Reply #3 on: September 17, 2013, 07:32:29 AM »
Something is not KOSHA here  :ShakeHead: ....according to ISO
...an M5 SHCS has an inhex  AF or W dimension of 4 mm......
...an M4 SHCS has an inhex  AF or W dimension of 3 mm....so a measurement of 2.98mm for the corresponding hex driver key size is acceptable
When one purchases a hex key set.... :Director: are they not based on the AF sizing?........which has little to do with the thread sizing designation :facepalm: .....Derek
Offline tel
Re: Dodgy Hex Key
« Reply #4 on: September 17, 2013, 07:40:28 AM »
Yes. Allen keys are designated by the a/f size - here we have an acceptable 3mm key branded as a 4mm, which is clearly not acceptable.
Offline mcostello
  • Lancaster, Ohio
Re: Dodgy Hex Key
« Reply #5 on: September 17, 2013, 04:51:11 PM »
I doubt anyone in China has a red face over anything they do. They figure We are foolish enough to buy their stuff. (Got my share also.) :'(
Offline tel
Re: Dodgy Hex Key
« Reply #6 on: September 17, 2013, 09:26:30 PM »
... more likely having a quiet chuckle over it in a corner somewhere.  ;)
Offline Noitoen
  • Setúbal - Portugal
Re: Dodgy Hex Key
« Reply #7 on: September 17, 2013, 09:29:16 PM »
You have it wrong. 4mm on the handle means it's for 4mm screws :cheers:
Offline tel
Re: Dodgy Hex Key
« Reply #8 on: September 17, 2013, 09:34:29 PM »
I've never seen allen keys designated that way - for starters while the 3mm key will fit an M4 cap screw, it won't fit an M4 c/s screw.
Offline Noitoen
Re: Dodgy Hex Key
« Reply #9 on: September 17, 2013, 09:51:47 PM »
Just kidding ;)
