Author Topic: Radiator Ramblings  (Read 7844 times)
Re: Radiator Ramblings
« Reply #15 on: March 19, 2013, 09:52:57 PM »
Hi Bill,
I just left it as pictured although adding more volume would have helped. These little engines get hotter than what you'd believe. I'm going to check the capacity of the new radiator I bought against the one on the 4 cylinder engine. If it has substantially more I'm going to switch them out. I'd hate to loose the shiny brass radiator but if it helps the engine run cooler then that's the best way to go.
Database Error
Back
