Model Engine Maker
Help! => Hints, Tips & Tricks => Topic started by: Joco on April 09, 2017, 08:40:15 AM
Title: Hafco AL320G - Threading Dial
Post by: Joco on April 09, 2017, 08:40:15 AM
I've been looking at the threading dial on my AL320G and thinking it must be usable even though the "manual" that comes with the lathe doesn't tell you anything other than how to set up the change gears.
So first off some research into threading on the lathe by reading Workshop Practice Series #3: Screwcutting on the Lathe by Martin Cleeve.
Now this is pretty jolly complete and after reading things several times I felt I had enough of a handle on things to make the next steps.
So looking at the threading dial the gear is 20 teeth, the lead screw is a 3mm pitch and the dial has 4 "lines" or sectors on it.
So what does all this tell us ... well after some manual measurements the following ...
We get 60m travel of the saddle from a single rotation of the threading dial and the lead screw turns 20 times during that travel.
i.e. 20 teeth x 3mm pitch = 60mm travel.
So back to the book, specifically from pages 71 with specific attention to pages 81 and 82. So from reading this section it appears that the key to being able to use the threading dial is that the pitch of the thread needs to fit some rules with regard to:
[1] the thread pitch being a whole multiple of the leadscrew pitch
[2] the thread pitch being able to divide evenly into the amount of saddle travel represented by sectors on the dial
So armed with this hopefully correct info I built a chart to see what pitched threads I could use the dial for on the lathe and which I could not.  And that is the kicker with metric threads, not all of them will work with the threading dial without some changing in the threading dials gearing.
Pic #1:
The calculated table of threads.  Blue lines show thread pitches not possible with the stock threading dial gearing.
Pic #2 & #3:
Now to do a proof.   I picked a 1.5mm thread, setup the lathe gears, found some scrap and got it ready to do some light cuts.
Pic #4:
So, set up the and ready to go I had the lathe running nice and slow (60rpm) and leadscrew turning and ready to engage the half-nut on a any whole sector line on the dial. Let it run a light scratch, disengaged the half-nut, pulled back the cross slide, brought the saddle back to start position, shutdown and checked with a gauge.  Photo's not the best but you can see that the scratch is bang on the 1.5mm pitch gauge.   So far so good.  Now for the moment of truth, can we get repeated pickup?
Pic #5:
Well repeated the same process and engaged the half-nut on one of the whole sector lines. Not the same as the last one, just to make sure there was some more variability in the mix.  Re checked the slightly deeper cut, BINGO, bank on the same lines as last time.
Pic #6:
Okay according to my understanding from the book learning I should be able to engage the half-nut at ANY point on the dial gauge as the 1.5mm is a whole multiple of the leadscrew pitch.  So thats what I did, engaged the half-nut at a point between the sector lines on the threading dial.
And the result was bang on!
Pic #7:
I ran out of time tonight to do some more variations on threads, also will need to dig out some more scrap round to trial on.  But so far the math seems sounds and practical testing is lining up with the book learning.
Conclusion at this point is that while not all threads can be done using this method a good chunk of them can be so the threading dial is no longer looking like the useless appendage it seemed to be for metric threading.
I'll do some trials over the course of the week plus I want to look into what gearing would be needed on the thread dial to do the other threads and if that is even worth the hassle given the non-disengaged half-nut method will work just fine on those.
Cheers,
James.
Title: Re: Hafco AL320G - Threading Dial
Post by: Joco on April 09, 2017, 11:03:10 AM
Based on a prompt from from another dialog on this topic ...
I think on my leadscrew a 21 tooth gear on the dial indicator will get me the missing pitches. 21 * 3 = 63mm per full turn
For 0.45 pitch: 63 / 0.45 = 140.
For 0.7 pitch: 63 / 0.7 = 90.
For 1.75 pitch: 63 / 1.75 = 36.
Therefore a 21 tooth gear will give these pitches on a full turn and half turn. It will give the 1.75 and 0.45 on each quarter segment.
So I guess I need to source a 21 tooth gear.
Post by: gerritv on April 09, 2017, 12:49:35 PM
I vaguely recall seeing a photo of a SB threading dial attachment with multiple gears for just this situation although it was for metric threads on inch leadscrew.
Here is one solution: http://www.practicalmachinist.com/vb/south-bend-lathes/cutting-metric-threads-156039/
Gerrit
Post by: kvom on April 09, 2017, 02:45:09 PM
Your calculations seem to depend on the spindle turning an integral number of times the rate of the leadscrew.  Since the lathe has a gearbox, that ratio may well be altered enabling cutting of threads not related to a 1.5mm pitch.
Post by: Joco on April 09, 2017, 08:16:17 PM
Kvom - for this test I happened to use a 1.5mm pitch but I did the calcs for all the metric pitches I would likely be interested in.  Refer to the first pic.
I hope to get some time this week to do some proofs on a couple of other pitches. Particularly ones that need to be alligned with a segment line to work out. That being achieved, as you noted, by changing the gear setup.   It should all work but i want to see physical proof first.   :old:
Cheers,
J.
Post by: Joco on April 09, 2017, 08:20:47 PM
Gerrit
Gerrit - thanks.  Now I have started delving into this more I am finding and getting pointed to more of these types of mods.  Jus something else to add to the growing shop project list.   :thinking:
Post by: Joco on April 10, 2017, 09:15:15 AM
Managed to do a test this evening using a 2mm pitch and following what I have worked out got the thread restarts using the threading dial bang on each time.
The key of this test was that the restarts had to be done on a half turn.  Which I did and it worked perfectly.
I have updated the chart a bit on the basis I need a 21 tooth gear to get the extra pitches covered.
Cheers,
J.
Post by: John Hill on July 07, 2017, 08:09:44 AM
Hi, according to my notes if your lathe has a 3mm pitch lead screw:-
No need to use the indicator for:
0.5, 0.6, 0.75, 1, 1.5 and 3mm pitch
With a 16 tooth pinion:
0.4, 0.8, 1.2, 1.6, 2, 2.4, 3.2, 4, 4.8 and 6mm pitch
With a 15 tooth pinion:
0.45, 0.9,   1.25, 1.8, 2.25, 2.5, 4.5, and 5mm pitch
With a 14 tooth pinion:
0.7, 1.4, 1.75, 2.8, 3.5 and 7mm pitch
Sorry but I dont have a list for the indicator sectors..
Post by: Maryak on July 09, 2017, 01:12:10 AM
Hi Joco,
I have a Hafco AL320G and IIRC the information in the User Guide is misleading.
Some time back I decided to calculate what could and could not be done with the as provided change gears.
Attached is a spreadsheet which I hope you find useful.
Regards
Post by: Joco on July 09, 2017, 03:18:35 AM
Hi Joco,
Regards
Thanks Bob.   Is the information in the manual wrong or just incomplete?  I have done a few threads now using the gear chart as provided and things have been bang on the money.  So what is provided seems accurate, it just might not be as complete as it could be?
Cheers,
james.
Post by: Maryak on July 10, 2017, 01:27:46 AM
Hi James,
In my user guide the chart has a paper paste over which is not much better than what was underneath. From memory it's not so much wrong as it is incomplete and has better, more accurate gear combinations than those advised by the manufacturer.
Regards
