Model Engine Maker
Engines => Restoration of Model Engines => Topic started by: Stilldrillin on September 18, 2013, 11:01:38 AM
Title: Gold Blend. Dark Roast........
Post by: Stilldrillin on September 18, 2013, 11:01:38 AM
This is my, "Gold Blend" engine. During construction...........
(http://i110.photobucket.com/albums/n95/Dayjo/P1010737-1.jpg) (http://s110.photobucket.com/user/Dayjo/media/P1010737-1.jpg.html)
 At the recent show. Running very well, as usual.   :ThumbsUp:
Towards the end of the day, I went for a walk round, to see the other tables. About 1/4 hour.  :)
When I returned, black smuts were coming from the firebox. And it was blummin HOT!!!  :o
The twin, beeswax candles, had spontaneously combusted........   (http://serve.mysmiley.net/mad/mad0235.gif) (http://)
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030870_zps84c2965e.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030870_zps84c2965e.jpg.html)
Balsa wood doesn't like high temperatures.........
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030874_zpsadfb7852.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030874_zpsadfb7852.jpg.html)
The outside of the cap had a thick coating of soot. And, some pretty colours inside........
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030875_zpsc6d48f64.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030875_zpsc6d48f64.jpg.html)
And a sticky, smelly deposit on the piston and displacer rod. Action jammed.......
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030876_zps2c3f385a.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030876_zps2c3f385a.jpg.html)
Time for another rebuild!  :facepalm2:
Sigh.......
David D
Title: Re: Gold Blend. Dark Roast........
Post by: b.lindsey on September 18, 2013, 11:15:47 AM
Yep...I would say she got hot alright!!  Doesn't look like any damage that can't be fixed though...and a very nice looking engine too David!! When you get it back in ship shape, I would enjoy seeing a video of it running if possible.
Post by: steamer on September 18, 2013, 11:28:19 AM
The damage seems very minor ....I'm sure you can sort it!... :ThumbsUp:
Post by: Stilldrillin on September 18, 2013, 11:34:00 AM
Bill, Dave.
Thanks for your comments! (http://freesmileyface.net/smiley/respect/respect-048.gif) (http://freesmileyface.net/free-respect-smileys.html)
Nothing that can't be fixed.......  ;)
Here's the build story, and videos. If you have the time...... http://madmodder.net/index.php/topic,5732.0.html
David D
Post by: Stilldrillin on October 15, 2013, 07:18:02 AM
Hmmm...... Almost a month gone, already!  :o
Not had much workshop time, recently. Just a few minutes, here and there......  :shrug:
I made up a bundle of offcuts, to give a 4" square cube.........
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030883_zpsa6d57b76.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030883_zpsa6d57b76.jpg.html)
And started to turn it into a former, for the new displacer. Messy stuff.........
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030886_zps128ceb4f.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030886_zps128ceb4f.jpg.html)
Finished article.........
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030887_zpsacffb976.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030887_zpsacffb976.jpg.html)
Wrapped tinplate around, and soldered the overlap..........
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030900_zps1350fabc.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030900_zps1350fabc.jpg.html)
Two off, 3mm thick end discs. Thinned to 1mm, where possible........
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030895_zps942ea1c6.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030895_zps942ea1c6.jpg.html)
The wooden former, held the disc square to the tube, while I drilled for 6off 1.5mm dia rivets
Natural ingredients only, for my engines.......
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030902_zps3250d521.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030902_zps3250d521.jpg.html)
Then rolled the tin over the end cap, and tidied up with a gentle touch on the grinder.........
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030903_zps8a6d28a4.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030903_zps8a6d28a4.jpg.html)
Internal boss for the 4mm threaded displacer shaft.......
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030904_zps6a7c5445.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030904_zps6a7c5445.jpg.html)
Held with 2off M2 grubscrews, and hi temp sleevelock........
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030907_zpse3f46bb5.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030907_zpse3f46bb5.jpg.html)
The assembly spins true, within half a mm. Close enough........
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030912_zpsea75fea5.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030912_zpsea75fea5.jpg.html)
Initial runs, on twin candles were disappointing.
The hollow displacer sounds to be grinding/ grating as it slides through it's bush. Quite noisy!
Not a coffee table engine any more!
The new displacer weighs 94grms. The original one weighed 69gms, after toasting. The extra weight caused a hesitation, getting over TDC.
So I added 3 extra,  2" x 1/2" x 1/8" weights to the flywheel........
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030910_zps9b91a3b8.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030910_zps9b91a3b8.jpg.html)
Didn't make any difference! (http://serve.mysmiley.net/mad/mad0235.gif) (http://)
So, I tried with my temporary meths burner, and it ran happily. Well balanced, even up to blurred revs.  :ThumbsUp:
I feel another, stainless burner coming on.......  ;)
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030913_zps47505b24.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030913_zps47505b24.jpg.html)
David D
Post by: jwcnc1911 on October 15, 2013, 01:52:44 PM
Tht's got to be the best looking "can" Stirling I've ever seeen.  Nice work on that thin metal there.
That thing looks huge, what's the bore/stroke?
Post by: b.lindsey on October 15, 2013, 02:35:07 PM
I agree with JW...well done on the new displacer too!!  Looking forward to seeing it running as well.
Post by: V 45 on October 15, 2013, 03:02:35 PM
I simply love Trecle !! Is that how it’s spelled ? Never called it anything else. I grew up with the stuff, but haven’t had any in years. I haven’t been able to find any in the states. While I was deployed overseas I ran into some British soldiers and asked them if they had any Trecle….they all laughed at me for asking that way and said I must be really old to call it that !! I'm not that old !! But in the end I had acquired a big tin of the deliciousness. I reminded me of home while I was in a very hostile environment !! It was very soothing at the time and place to have some home comfort reminders. Anyway…just thought I would pass that along…..good use of the tin !!
Post by: fcheslop on October 15, 2013, 04:38:53 PM
Aye up David, its grand ta see t engine coming back together glad youve managed un shop tahm :ThumbsUp:
cheers
Post by: smfr on October 15, 2013, 04:46:56 PM
It's good stuff, that treacle! My wife orders it through Amazon :)
Simon
Post by: V 45 on October 15, 2013, 07:10:41 PM
Simon
[/quote]
 Cool...Thanx Simon ... will have to look for it again !!
Post by: Stilldrillin on October 15, 2013, 07:53:51 PM
JW, Bill.
Thanks for your comments! :cheers:
Displacer bore is 3 3/4", power piston 11/16", both strokes 1".
There will be a final video. Eventually.  :ThumbsUp:
Work to do on firebox, and new meths burner. Shop time is limited, unfortunately......  :(
David D
Post by: Stilldrillin on October 15, 2013, 08:03:28 PM
Dave V45.
I too have enjoyed treacle ("treekl"), over the past 70 yrs. Never did/ do call it by it's correct title!  :LickLips:
Use it in my morning porridge. Also, I use it in the flapjacks I bake, for my other forum's members........
(http://i110.photobucket.com/albums/n95/Dayjo/P22500011.jpg) (http://s110.photobucket.com/user/Dayjo/media/P22500011.jpg.html)
Never forgetting to finger clean out the residue, before washing and storing the empty tin.   :P
David D
Post by: Stilldrillin on October 15, 2013, 08:16:11 PM
cheers
Heyup Frazer.
Seems I need to teach you to speak proper Derbyshire. Ma Duck!  ;)
Thanks Marra!  :ThumbsUp:
David D
Post by: fcheslop on October 15, 2013, 09:16:42 PM
 :Jester: Im all ears marra
Im only a begginer  ma duck
Those flap  jacks look canny
cheers
Post by: Stilldrillin on October 26, 2013, 10:54:57 PM
And..... Here's the burner, that was coming on, a couple of weeks ago!  (http://serve.mysmiley.net/rolleye/rolleye.gif) (http://www.blueislandsdiving.com)
Usual build. Top of a salt grinder/ pot.
Brass disc, base, with central locating bar, and supporting foot underneath the wicktube.......
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030935_zpse5e51b85.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030935_zpse5e51b85.jpg.html)
The crossbar locates nicely, in the rim of the bowl/ firebox.......
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030937_zps93806afb.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030937_zps93806afb.jpg.html)
Until, my fumbly fingers knocked the burner, fully inside the firebox!   :facepalm:
The only way to retrieve, was to lift the hot engine, while it was running.  :(
A taller, breather tube, stopped that happening again.........
(http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030941_zpsd57800af.jpg) (http://s110.photobucket.com/user/Dayjo/media/Return%20Album/P1030941_zpsd57800af.jpg.html)
Here's another, final video........
https://www.youtube.com/watch?v=FTkAVbJcbR4
Job's a good un!   :cartwheel:
David D
Post by: fcheslop on October 27, 2013, 12:21:01 AM
Hey up marra, A nice rescue :NotWorthy: :NotWorthy: :NotWorthy:
Whats youre lass going to say about the salt pot. I will have a look for some of them as I need a couple of burners soon.
cheers
