Model Engine Maker
Help! => Machines, Tools and Fixtures => Topic started by: Gas_mantle on February 24, 2019, 05:00:54 PM
The title says it all really, I've been kinda thinking of buying one but they seem to get a bit of a bad review from the DIY fraternity.
I don't want one to tackle any real heavy work, it will only be for a bit of sawing, filing, painting etc and as a suitable bench to steam engines up outside. They seem to come in a variety of different sizes and flavours so I wondered if anyone here has one, what model they have and is it any good etc?
Many thanks.
Don't think any of the subsequent ones are quite as good as the original cast ali ones but they are still useful things to have. My brother has the original cast one that my dad bought when they first came out and I have a couple of steel ones that must be 25+ years old.
I have an original blue B&D MkII workmate that was purchased second hand for the princely sum of £1 over 25 years ago ;D It recently (about 5 years ago ::) ) had its bits of the brown stuff covered with thicker bits of brown stuff but it is still going strong. The aluminium sub frame is a bit oxidised :-X
I also have a pair of those cheap (£10 new) folding work tables.
It all depends what you want one for... Mine is now used as the engine running bench :ThumbsUp:
Thanks, this kinda thing looks reasonable for the kind of light work I'll be doing - says it will support 250kg which seems a lot to me.
https://www.amazon.co.uk/BLACK-DECKER-Deluxe-Workmate-WM825-XJ/dp/B0001GRVYG/ref=sr_1_1?ie=UTF8&qid=1551028500&sr=8-1&keywords=black+and+decker+workmate
I have a couple of the original ones, big cast frames, two level fold down legs, etc. They were absolutely great, I use them a lot for many jobs.
I also have a newer one, which weighs much less than the originals since it is stamped out steel sections. Still, a very handy unit, but not heavy enough to stay in place when doing large carving jobs. I mainly use it as a portable bench out in the garage for things like silver soldering. It is light enough to pick up and carry out to the driveway, put layers of firebrick on top for the soldering work. Also handy for sanding, cutting boards, etc.
While not built like the originals, the new ones are plenty good for a portable bench for light to medium work. For heavier jobs that need a bench that wont shift around, you could just load up the bottom with sandbags or bricks. The newer ones are much easier to transport, the originals were quite heavy and awkward on stairs or into a car. Either way, the do fold up fine. I have never had either new or old ones break on me, they get a lot of work.
I have two B&D workmates, the versions with stamped steel parts, both over 30 yr old. Nothing handier than these things for outdoor construction or holding large lumber for drilling, sawing, fastening . Also great for holding big awkward metal things for welding. Excellent for holding awkward shaped heavy bits while rebuilding motorcycle and small equipment engines from the smallest to a 750 cc Yamaha Maxim 4 cyl. The only parts I have broken on the workmates are some plastic D shaped gizmos that act(ed) as springs to keep the bottom legs folded up, and one wood top jaw that I seriously overloaded (my fault entirely) with a big full size tractor engine part. I made a new top jaw in plywood and it's been fine since, despite serial abuse within load limits, and I tied up the swinging legs permanently down with strips of perforated metal and some screws. Very happy with the ones I have. :Love:
I too have one of the stamped steel ones, at a guess I've had it for at least 30 years.
loads of abuse...never breaks.....agree with all previous comments . good tackle! Terry
Many thanks everyone, I'll treat myself :)
To be honest now the warm weather is here I've been practising steaming engines on coal and could do with some kind of portable bench just for that.
I have one of the original two level jobs, given to me by my dear old Dad as a slightly delayed Wedding present way back in 1969. Wouldn't be without it!!
cheers
Peter -
as far as I'm aware they vary in quality, some being sturdier than others, so if I were you I'd look and see if there are different versions. There are also some equivalents around made by other manufacturers.
In any case, though, they are handy things to have as we all need that extra bit of working space sometimes, and they don't take up too much room when folded.
gary
I have seen them for years and thought that they were not really any good. Until I saw a friend using a pair of them and I was a convert.
I went out and just got one to start with as the model he had was like 15 years old and no longer made. It was so good I went out and got a second one.
Just so handy. The last few days, I have been using it for a test stand holder for running F3D 6.5 cc pylon race engines.
Apart from all the home renno jobs etc. I would not want to be without them now. Wish I did not have bad preconceived ideas about them for the last 20 years.
There are copies of them about for sure, but the ones I have , just have a nicer feel with the clamps and the way the boards sit into the frame for adjustment etc. It also has 3 height settings as well, all folded down, just the bottom legs, or lifted up.
Neil
I have a very small shop. What I like about it is I keep it folded up out of the way then when need be set it up outside or wherever I will do something on a temperary basis. I have had mine over 20 years.
I have two Workmates, one original, and one later model, and both have proved invaluable over the years. As regards weight capacity, I have used mine to hold full size stationary engines, some of which have been pretty heavy.
Black and Decker products certainly seem to have been made to last in those days - I was given a Black and Decker drill as a 21st birthday present and it still works now (I am 72). In fact, the drill is probably in better condition than me!!
I have one of the original Black and Decker workmates, which is still going very strong and as an accessory I purchased a similar one from Lidl at the huge cost of £10 and whilst not as rigid as the original still works very well, considering the price.
I think they are excellent, very useful for a whole range of jobs.
The “ jaws” will hold slightly tapered items and the bench can be set at three different heights.
They can carry a lot of weight, i currently have a 4 cylinder motor engine sitting on mine.
Trevorc
I have a couple of them and they're useful for all sorts of things from sawing logs and making shelves to holding large steel bars while I hacksaw through them and subbing as an engine test stand for (as with Neil) FAI-F3D pylon racing engines. In fact back in the days when I competed in FAI-F3D my team-mate and I used to take two workmates to every race meeting - even the European and Wold Champs ones (my F3D workmate has tens of thousands of air moles!).
At race meetings they could be used to hold the engine test stand, and then with the jaws about 4" apart and a folder towel thrown over the top they formed a perfect model stand for working on models between races. The fuselage sat inverted in the gap with the wings lying on the flats in a perfect position to remove the cowl, motor & pipe, clean it all down and then refit & tape-up ready for the next race. If there was a wind it just needed a bungee strap lightly over the top to hold it all there safely while I went off to call for my team-mate. Then with a square foot of 5mm alloy plate clamped in the jaws they made a perfect field-hearth for re-brazing pipe brackets onto pipes and repairing undercarriages with technoweld.
I have one of the early die-cast alloy ones and one of the later pressed-steel ones. There's nothing much to choose between them - the little plastic clips that keep the feet stowed when it's folded up have failed on both, but that's just a minor annoyance. If pressed I would probably prefer the steel one because I can stick things to the sides with magnets, and because if it broke the pressed steel parts can be easily repaired with some steel sheet and pop-rivets or silver solder. I think the alloy one would be tricky to repair if any of the die-cast bits broke, but neither shows any signs of breaking so it's a theoretical concern only.
So I guess that's a big positive recommendation from me!
AS
Many thanks to all those who offered help, the consensus seemed to be they are a useful thing to have so I ordered one of these :-
https://www.amazon.co.uk/BLACK-DECKER-Deluxe-Workmate-WM825-XJ/dp/B0001GRVYG/ref=sr_1_1?crid=12C4KE7342XWS&keywords=black+and+decker+workmate&qid=1552421329&s=gateway&sprefix=black+and+dec%2Caps%2C165&sr=8-1
They seem to come in various sizes and flavours but at £80 I thought it looked be ideal for my needs.
You won't regret the purchase..........only possible other consideration..... :stickpoke: ordering a pair [two] identical benches
They can make great :lolb: loungeoom furniture .....
Derek
