Model Engine Maker
Supporting => Engine Ancillaries => Topic started by: Brian Rupnow on April 10, 2014, 12:28:36 AM
When I built my Philip Duclos "Odds and Ends" engine a couple of years ago, I never did build a satisfactory gas tank. I have some "down time" now, so thought perhaps I should build a gas tank for it. Since I don't have a separate base that the engine mounts on, I have decided that the gas tank must mount on the engine itself. A hunt through my "bits and pieces" bin yielded a length of galvanized steel tubing 1.165" outer diameter x 1/16" wall thickness. I didn't want to have to deal with the galvanized finish, so I set it up in my lathe and turned the outer diameter to 1.144" diameter, which (I hope) got rid of the galvanizing on the o.d. of the pipe. The piece I turned is 3.48" long. This was a somewhat arbitrary length, but all that matters at the moment is that it be 'long enough". In the picture you can see the unturned length and the turned length setting in front of the engine.
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/GASTANK-1001_zps72d24e7b.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/GASTANK-1001_zps72d24e7b.jpg.html)
I had already modelled the engine before I built it, so today it was simply a matter of bringing up that cad file, and adding in the tank body (in red) and designing a bracket to hold the tank (in dark blue). I have some thoughts as to what the rest of the tank is going to look like, so tomorrow will model them and then setting about building them.
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/ASSEMBLY-ODDSNENDSWITHGASTANK-1_zpsae84ea4e.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/ASSEMBLY-ODDSNENDSWITHGASTANK-1_zpsae84ea4e.jpg.html)
I don't expect that anyone is going to build this, however---I have to build it myself, and I need a drawing to do it. It requires no effort for me to post it, and it gives the new guys something to think about. The steel gas tank body will be inserted into the round hole in the bracket and secured there with #638 Loctite. The only thing of importance with this bracket is that the top of the gas tank MUST be 1/2" to 3/4" below the center of the carburetor barrel. The small carburetors on these hit and miss engines have no float and shut off valve, so if the level of fuel is ever higher than the fuel port in the air intake/needle valve assembly in the carburetor they will flood like crazy and fuel will gravity feed from the tank and drip out the air intake side of the carburetor. This makes the engines almost impossible to start and can also be a major fire hazard.
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/GASTANKBRACKET_zps57766f91.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/GASTANKBRACKET_zps57766f91.jpg.html)
Had me going there for a minute until I woke up to the fact that some of us call some liquid fuels like petrol............gas.!!!!
The joys of our common language :Lol:
Best Regards
This gets rather interesting as the design develops. One picture shows what the finished engine looks like mounted on the engine. The other picture shows a section view through the center of the tank. This is going to be a "no soldering involved" tank, completely assembled with 638 Loctite. The main tube is mild steel, the ends are machined from aluminum, and the filler neck and cap will be machined from purchased brass plumbing fittings. The small tube that runs out to fed the flexible gas line will be machined from mild steel. I'm not 100% sure yet, as to whether I will use 638 Loctite as the bonding agent or J B Weld. They both stand up well to fuel immersion, and they both are super strong when fully cured.
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/ASSEMBLY-ODDSNENDS-FINISHEDGASTANK_zps6ee97a00.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/ASSEMBLY-ODDSNENDS-FINISHEDGASTANK_zps6ee97a00.jpg.html)
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/GASTANK-ODDSANDENDSENGINE-SECTIONVIEW_zps9450846a.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/GASTANK-ODDSANDENDSENGINE-SECTIONVIEW_zps9450846a.jpg.html)
C'mon, Brian, how about a window on the end so you can see your fuel level... :stickpoke: By the way, your concept is very close to what I had on my original Odds'n'Ends engine
Chuck
Chuck--You're right!! That's about the only place there is for a tank on those engines. I do have an extra glass lens laying around too, but I can't put it on the filler cap end, and the other end is obscured by the flywheel.--Oh well---I'll just have to unscrew the cap and look down the hole to see how much fuel I have, same as all my other engines except the Atkinson.---Brian
Brian,
do you need to worry about heat transfer? If so perhaps 2 small spacers between the tank mount and the engine will provide a thermal break?
Gerrit
Gerrit--I'm not worried about heat transfer. The tank is filled with water to keep the cylinder cool when the engine is running.
I must apologise for the photograph attached, it is a scan from an old 35 mm Photograph. This is Philip's engine running Compression / Ignition style. You can just make out the two "Omega" shaped brackets holding the tank to the cylinder block. I have since converted this engine back to petrol (gas) ignition and I have no problems with heat transfer as the brackets have very little Thermal mass.
My best regards
Gray,
While driving around town to buy some material, I got thinking about this tank. It needs one more hole thru the aluminum at the end where the filler cap is, to prevent it "air locking" as it is filled with fuel. Without the hole which I have added, I would have only been able to fill the tank to the top of the center hole thru the aluminum, and then it would have air locked and not taken any more fuel. With the added hole, any trapped air can escape and let me fill the tank almost to the top. I also added a breather hole thru the center of the screw on cap. The threads on the inside of the cap are tapered pipe threads, as are the threads on the fuel filler pipe, and I have found that even though I unscrew the cap a full turn to let air into the tank while the engine is running, the weight of the cap makes it vibrate closed and shuts off the air flow, causing the engine to starve for fuel, again because of an "air lock" situation.
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/GASTANK-ODDSANDENDSENGINE-CROSSSECTION-2_zps401ad0c3.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/GASTANK-ODDSANDENDSENGINE-CROSSSECTION-2_zps401ad0c3.jpg.html)
In the picture you can see the "gas cap" as purchased. It has a rough cast exterior. Beside it you see the same part, after a little cosmetic work in my lathe. (That's the gas cap off my dual opposed piston engine). The pipe nipple which the cap screws onto will have one end cut off and be turned down to match the hole in the aluminum tank end. Also shown in the picture is the "blank" end cap for the far end of the gas tank. There is a small trick to it. It has to intrude into the end of the tank about 1/2" to ensure enough material that the Loctite can get a good leak-proof bond between it and the outer tank shell, but if I didn't but the big counterbore in the end of it, I wouldn't be able to get as much fuel into the tank as I want. This way, the counterbore fills up with fuel too, so I don't lose much tank capacity.
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/GASTANKPARTS002_zpsa9856a81.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/GASTANKPARTS002_zpsa9856a81.jpg.html)
Hey!! I'm starting to like this!!! There is a lot of work in that large aluminum end, but all the parts go together and I think it looks good. I have temporarily ran out of 638 Loctite, so I am going to do all of my assembly with J.B. Weld. I have two tubes of it that may never get used up, so they might as well be used for this.
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/GASTANKALMOSTDONE002_zpsca2d5a33.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/GASTANKALMOSTDONE002_zpsca2d5a33.jpg.html)
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/GASTANKALMOSTDONE003_zps156356ed.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/GASTANKALMOSTDONE003_zps156356ed.jpg.html)
It doesn't get a whole lot better than this---as far as fit goes, anyways. There is a small bit of deception in the picture, because I haven't completed all of the joints which are being "glued" together with J.B. Weld. I haven't used J.B. Weld in an application like this before, so want it to have a full 24 hours drying time before I put any pressure on it or try to put fuel in the tank. I will finish those joints this afternoon and then wait a couple of days before I test it with fuel in it.
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/GASTANKMOUNTED001_zps3f9ef8e3.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/GASTANKMOUNTED001_zps3f9ef8e3.jpg.html)
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/GASTANKMOUNTED002_zps441c90fc.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/GASTANKMOUNTED002_zps441c90fc.jpg.html)
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/GASTANKMOUNTED003_zps140a5b40.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/GASTANKMOUNTED003_zps140a5b40.jpg.html)
Looks real nice, Brian! I'm sure the JB Weld will hold up OK. On my version of the Odds'n'Ends, pictured earlier, the entire Cylinder Assembly is JB Welded to the steel plate that screws to the engine frame. I know that sounds like a kluge, but, after a lot of thought, I actually engineered it that way and it's held together with no problem for over 15 years.
Chuck
Thanks Chuck!! I thought that probably the J.B. Weld would work okay for this application. Its really not a "strength" application as much as it is a "sealant" application. I finished everything off this afternoon, now I will let it all set for a couple of days and then try some fuel in it.---Brian
Here is a short video with the new gas tank on the running engine. There is a link to Photobucket, also to Youtube.
https://www.youtube.com/watch?v=mxc_NZ_29yc
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/th_ODDSANDENDSENGINEWITHNEWGASTANK_zps01af33ad.jpg) (http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/ODDSANDENDSENGINEWITHNEWGASTANK_zps01af33ad.mp4)
Now I have to play detective. I'm really not sure if that annoying "clank clank" noise is from the long rocker arm or not. EDIT--I think perhaps its just the nature of the beast. That desk the engine is running on is hollow, and it amplifies all the sounds like a drum. Since I have everything out to run my engines, I have put away the Odds and Ends and am now running my Kerzel on the same desk, and its twice as noisy as it is when its running on my heavy work bench out in the main garage.--I'm not going to worry about it!!
I took another look at the engine trying to run down that clank clank noise--its making me crazy. I have just found out that when the roller bearing on the end of the long rocker arm is fully "up" on the tip of the cam, there is no slack in the system anywhere. It seems that the exhaust valve is open as far as it can go, and is actually "bottoming out" against the head of the intake valve.--Definitely not a happy thought. The only thing preventing major damage from being done is that the long thin rocker arm has some flex in it. I am going to adjust the shcs which bears against the head of the valve until I have a bit of clearance in the "exhaust valve open" position and see if that gets rid of my clank. I held the intake valve open with my finger and rotated the engine by hand, and I can actually feel the exhaust valve hit the head of the intake valve and force it up.
(http://i307.photobucket.com/albums/nn294/BrianRupnow/BrianRupnow013/enginenoise002_zpse0a0a307.jpg) (http://s307.photobucket.com/user/BrianRupnow/media/BrianRupnow013/enginenoise002_zpse0a0a307.jpg.html)
Brian, I have a similar noise on my Plumbing Parts engine. I finally figured out it happens as the cam follower rolls across the tip of cam lobe. As it goes past the tip, the lateral deflection on the roller shifts 180 degrees. Here's a picture.
(http://i192.photobucket.com/albums/z195/cffellows/CamDeflection_zps9ad5869e.jpg?t=1397588450)
This change causes a click as the follower assembly shifts position because of the change in lateral deflection.
Chuck
That's better. With the adjustment made t the rocker arm, the clank clank noise has pretty well disappeared.---Brian
https://www.youtube.com/watch?v=5TOnOTxVwZU
Chuck--there are a lot of things on these little engines that "go bump' and not necessarily in the night!!! Sometimes it talks a bit of detective work to figure out what the heck is making the noise.---Brian
