Model Engine Maker
Engines => Restoration of Model Engines => Topic started by: Bobsmodels on May 22, 2019, 01:49:36 AM
I am restoring a 2” Case Traction Engine’s valve system. This engine has been running for about 25 or so years. Operating via belt some attachments for display. I acquired the engine several years ago and noticed it did not run smooth. Having been in the live steam hobby for over 25 years before switching to small model Hit and Miss engines I knew some work would need to be done at some point. Last fall at the last run the engine just would not start unless I flipped the flywheel. I checked around and discovered the steam leaks I had been observing had finally really got out of hand. I had steam coming out of both cylinder cocks and the stack at the same time. I guessed the valve face or something in the steam chest was really amiss. In addition, I could move the valve stem almost a .25 inch when in a notch, indicating the linkage was really worn.
Last month I started disassembling the engine. In the pictures you can see how badly pitted the steam port surface had become. Even the port edges were no longer crisp. I was not sure how much would have to come off and decided to use my surface grinder rather than the mill to clean it up. I felt I could control how much came off more easily. As you can see from the progression I had to remove .041 to clean up the surface. The pitting did not look that deep at first.
As can bee seen the right port edge needs to be cleaned up square, which also means the left port edge will need same amount taken off so there is equal distance from the center of the exhaust port to each side. I am not going to clean up any of the inside edges, just the leading edges at the start of steam admittance. I will need to make a new valve with added length to account for the increased width of the ports.
I have a question about the steam port surface. When reassembled the valve stem will be offset by the .041 I took off. I have two choices. I can make an offset adjustment on the valve stem linkage to account for the .041. Or, I have at one time seen a repair where a thin sheet of steel was made up the thickness of the repair (ie the .041). In that sheet the ports were machined to specification and after the valve face is lapped smooth it could be reused. The advantage of the sheet approach is all the original specs are back on the engine.
I can make the .041 sheet but have some concern about it staying flat and not buckling with heat, given it will be held down by the steam chest and have no way to expand.
My preference is to clean up the steam ports, make a new longer bronze valve (customize its length when setting everything back up), and offset the linkage.
Anyone use the sheet method or have an alternative suggestion.
Thanks
Hullo Bob....reading your post interested me, however I have more questions than answers
1. we see the green faced block in the red vice.....is the vice held on a magnetic table?
2. is the block supported on parallel strips in the vice?
3. is the block cast iron or cast steel? [red sparks or yellow sparks?]
4. how did you set the block to be best Law of Fit for initial flatness to start with?
5. is the white grinding wheel A60 or A120 [aluminium oxide?]
6. if red sparks were evident, did the wheel surface load up?
7. are you using coolant when grinding?
In your first paragraph you mention 0.25 inches........so we assume all other dimensions are also in inches!
Point 4. is critical........it is always best to start with a flat clean surface.....the photograph suggests another 0.41" is required for this an so the offfset is 0.082"....[or have I misunderstood?]
The - negative dimensions shown are different between images......nearly as though the block was not adequately supported
eg., right hand top corner = - 0.030, then - 0.091 in another image for the same location!?
how are you measuring the negative depth dimensions?
In some ways, a larger 0.82" would be easier to manage than an offset one 1/2 of this
I have no personal experience with slip steel shim plates, however the prospect is not sitting well :facepalm: in my mind
Derek
Hi Bob, just a thought - .041" is not a lot to take up. Did you look at the valve to check if it could be used as is just sitting lower on the rod? The valve should float on the rod, usually a few thou rather than .041", but it may work if the valve's shoulders the rod pushes on are still well engaged. If this approach can't work, I'd make a new valve, myself, rather than a thin sheet. I have seen 1/8" thick valve face plates used on some stationary engines.With a thicker plate I'be be a lot less worried about it catching an edge and peeling up like a can lid.... :facepalm:
Also attaching a .041" thin sheet will be difficult to do I think, without distorting it. Just food for thought. :thinking:
Good luck with it!
If the valve spindle needs to line up with the valve gear cut a shim gasket between the valve chest and the port face then make sure that the valve has enough clearance to sit on the port face .then the spindle will remain in the same place the vale can just move enough to slide on the port face .
Derek - see below
I agree, the plate will be difficult, much easier to adjust linkage.
Yes
No it was not necessary, see ans 4
Cast Iron
Block in the vise was set on a surface plate, the unworn four corners of the block were set to within .0005 of each other
I do not know I would have to pull it off
no red sparks
No coolant
Yes
I think the problem is with my writing on the block, the dimensions were all the same, ie first photo .020, second photo .030, third photo .041, just sloppy writing.
eg., right hand top corner = - 0.030, then - 0.091 in another image for the same location!? See above ans
On the surface plate ie I recorded the start dimension and simple subtraction to get the removed (negative) amount.
Derek
CNR6400, John
As I mentioned the ports are going to need to be cleaned up so if I do not use a plate, a new valve will need to be made, longer by the amount added to the width of the admission ports leading edges. Two choices, make a shim .041 to raise the steam chest and make valve stem hole in it .041 higher, or make valve to spec but longer and adjust linkage by .041.
Right now it looks like easiest approach is to just make new valve longer but in all other respects to the specifications and offset the linkage. Given the rocker arm that the linkage connects to has lots of material I may just take part off of it, and the rest off the loop on the end of the linkage rod. Net would be .041 removed.
Thanks for your thoughts on this
Hi Bob,
I'm kind of late to the game but my thoughts are that you want to keep the valve chest in the same position so the piping doesn't change. A .041 shim between the cylinder block and valve chest would accomplish this then I would just make a new valve.
George
You are absolutely correct. I forgot all about the governor sitting on top of the steam chest. It uses 5-40 mounting bolts so .041 would be huge on a .128 clearance hole and it would have cut off the steam flow! That would have been an unfortunate surprise.
Looks like the method has now presented itself. A .041 shim, clean up the ports, and make a new valve to match the new ports and the new hole for the valve steam .041 higher on the valve.
Thank You George
