Model Engine Maker
General Category => Chatterbox => Topic started by: gbritnell on January 13, 2019, 01:52:57 PM
Gentlemen,
One of my other hobbies is and has been since I was a kid is building plastic models. I still find the time between machining and artwork to knock out a few model builds every year. While perusing one of the plastic modeling forums I saw a review of a Holt 75 Artillery Tractor.
The kit is by Roden out of the Ukraine. I have never built a kit by this company before so I didn't know what to expect as far as quality. For those who build plastic kits know that kits run the gamut from very poorly researched and executed to fall together type kits.
Having built the Holt engine I have studied the Holt tractors and found that this kit follows the original quite accurately but lack as far as engineering. One of the worst flaws is it has a canopy representing the corrugated metal type found on this machine. On the underside is a rib that runs the length of the piece and as with metal casting when you have a thick section adjacent to a thin section when the material cools it shrinks to the thicker area and creates what's known as a shrink. In metal casting you have to provide risers to feed the shrinking area. This shrink area along the center of the roof line needed to be filled, filed and sanded all the while trying to maintain the corrugations of the roof.
There were other issues but that's not the purpose of the posting. It's just to present a neat looking representation of a 1918 Holt tractor.
That is a very neat machine, bet you could make a great working one in metal!
Turned out nicely George. Did you paint it or were the parts molded already colored?
Hello George,
More beautiful work done by you, even if it is a kit, really neat. What is the function of the front wheel?
Hi Bill,
The kit comes molded in green styrene plastic but everything needs to be painted.
Thomas,
The tracks could be controlled individually, just like a modern bulldozer so the only thing I can figure is with all the weight forward of the tracks the machine would be nose heavy therefore needing support up front. This is where the wheel comes into play. Even with the tracks being able to move the machine from left to right a steerable wheel was needed to get the front end where it needed to go. Watching videos on you tube shows the operator steering the wheel as the tractor moves.
