Model Engine Maker
Engines => Your Own Design => Topic started by: crankshafter on September 30, 2017, 07:43:10 PM
Evening all.
I'm in the progress of building a 1 cylinder IC engine of my own design, 35mm bore , cast iron rings, aluminum piston.
And here's a question: what clearance for piston/cylinder should aim for.
CS
A couple of thou will do it...
What is the cylinder made from, you made need more clearance with an aluminium piston.
Roger.
Sorry :embarassed:but the cylinder is cast-iron
CS
No, even with an aluminum piston, 0.002" clearance will be enough. Sometimes people deliberately make the piston about 0.001" oversize, then "wring it" into the cylinder using diamond lapping paste. If you do that, you can get away with no piston rings at all. That is effectively zero clearance, and is often used on two cycle engines where a piston ring would get caught and break on the cylinder ports. You wouldn't do that with an aluminum piston, because it expands more quickly than cast iron and could seize in the bore.
