Model Engine Maker
Engines => From Kits/Castings => Topic started by: Rivergypsy on January 20, 2017, 05:06:19 PM
Just a quick post to kick off the prep work on the next project, the engine which powered the railway workshop in Lyon in the 1800s. A friend, Rich Carlstedt shared an engraving of it he’s got with a few friends, and it just seemed plain rude to let all that detail go to waste
Solidworks modelling is progressing intermittently but nicely, so we should be looking to start work on castings and drawings in the not too distant future. To give an idea of scale, the flywheel will be just under 12” diameter.
(http://i1342.photobucket.com/albums/o779/rivergypsy219/Ateliers%20Engine/Ateliers%20-%20small_zpsppxmlsdm.jpg) (http://s1342.photobucket.com/user/rivergypsy219/media/Ateliers%20Engine/Ateliers%20-%20small_zpsppxmlsdm.jpg.html) (http://i1342.photobucket.com/albums/o779/rivergypsy219/Ateliers%20Engine/Ateliers%20Engine%20-%20Assy%2002_zpsifyagiq8.jpg) (http://s1342.photobucket.com/user/rivergypsy219/media/Ateliers%20Engine/Ateliers%20Engine%20-%20Assy%2002_zpsifyagiq8.jpg.html) (http://i1342.photobucket.com/albums/o779/rivergypsy219/Ateliers%20Engine/Ateliers%20Engine%20-%20Assy%2001_zps8dsgease.jpg) (http://s1342.photobucket.com/user/rivergypsy219/media/Ateliers%20Engine/Ateliers%20Engine%20-%20Assy%2001_zps8dsgease.jpg.html)
Beautiful engine Dave,
It will be fun to watch this one progress.
Oh, that one will be a beauty for sure...lots of detail work and the base will only add all the more to it in the end. I love it!!
That looks to be a fun project :ThumbsUp: :ThumbsUp: The gear system around the governor on it's own looks to be a complete project :headscratch:
I shall look forward to following this one along.
Funny enough after your post the other day I came across this while looking for something else
http://images-03.delcampe-static.net/img_large/auction/000/371/215/060_001.jpg?v=1
You don't need no stinkin castings. :noidea:
Hi Dave,
Now I know I better get another couple of hectares of :popcorn: planted!
Looking forward to this build!
Very nice looking design - I especially like the placement of the governor in the lower arch. Going to be watching along too!
Kerrin - pass the popcorn bowl! :popcorn:
Hi Chris,
Checked the field day before yesterday......coming along nicely!
Put you down for a couple of sack fulls! :lolb:
Many thanks everyone - i hope it'll be entertaining!
KVOM - funny you mention that, as fabrication has been at the back of my mind. However, there's 4 of us aiming to build this one, and Dennis (who did the compound castings) is up for the challenge :)
Jason - where on earth did you find that?! I've searched high and low to find more on this engine, even with extremely poor French, but to no avail...
I thought you might like that :)
Looking back through my history it seems it came up on Pinterest and as I had seen your post I saved teh image.
A bit more digging found some more images from the same set of ingravings but they don't show more of your project
http://delaby-vapeur.com/igaleriedelaby/?q=album/14-le-mecanicien-industriel-stanislas-petit
Only for information. There is similar engine in Nürnberg, Germany.
https://museen.nuernberg.de/uploads/tx_templavoila/maschinenbauanstalt-spaeth.jpg
Have you been able to figure out the valve? It looks to be two piece with the top adjusted by the wheel in back. Also, I'm wondering about the piping; unclear where the underneath pipe leads.
Better still is this version of the coloured engraving, you can zoom in enough to read the dimensions and text . Enjoy
http://gazo.dl.itc.u-tokyo.ac.jp/petit/limes/PL051-052.html
The whole book is indexed here for anyone with some time on their hands, couple of nice horizontals that would make a slightly simpler project.
http://gazo.dl.itc.u-tokyo.ac.jp/petit/category/cate04.html
That riding cut off looks very interesting!!! I like it!!!
It looks as though it is a Meyer expansion valve, but this is the first time I have seen one apparently controlled by the governor; they are usually adjusted manually. I love the fan-shaped thing on top of each expansion valve rod end, which I take to be a scale for a cut-off indicating pointer.
Yes but I'm trying to wrap my head around the mechanism that controls the riding cut off governor......hmmmmmmm
Looks like the shaft from the governor goes into a set of bevel gears (u) and rotates the valve rod, if the two pucks on the rod are L/H and R/H threaded then as the valve rod rotated that will move them to cover or uncover more of the valve below.
A similar thread on teh fan shaped dial pointer would let you see the movement of the pucks
... if the two pucks on the rod are L/H and R/H threaded then as the valve rod rotated that will move them to cover or uncover more of the valve below.
Yes, that is how a Meyer valve works. In playing around with the design of one some years ago, I found that I could more accurately match valve events over a wide range of cut-offs by using slightly different pitches for the two threads. I have two textbooks that discuss the gear in some detail, and neither mentions this possibility.
In this case I too am unclear how the movement of the governor causes the bevels to rotate. In any case I am unconviced as to how well it would have worked: one of the things to avoid in governor gear is friction, and this arrangement would have a lot of that.
It may be that the two bevels on the governor shaft are mounted on a helix so as the balls make the shaft go up and down the two smaller wheels rotate on the helix and then rotate the larger gears, this would only be a relatively small movement of the gears probably not even a full rotation so you would need quite a fast spiral on the valve rod too.
Yeah but whats confusing is the upper right hand view...which I assume is the governor mechanism...and then the general view with the bevel gears.
the shaft has a bevel gear on the valve spindle...implying it's part of the riding cut off mechanism....but look at the other end ...it's on a radial link joint...which means the shaft can't rotate.....we're missing something.....
Wow, some beautiful engines in the scans, and amazing draughtsmanship too - I can't believe this has just come to light after searching for so long.
In terms of the cut-off, hopefully with a little more modelling it'll be possible to turn the engine over and see quite how the it works at different governor positions. Here's a link to an early animation of the engine from late last year - https://www.youtube.com/watch?v=YG4fKuu6bKs
Many thanks again all for your help, input and enthusiasm!
Looking at the vertical view of the two valve rods it appears that they are separated laterally by 336mm as opposed to being one on top of the other in your model.
They look to both be in line and on the ctr line of the cylinder from above
Seems there must be some sort of offset in the rod between one end and the other.
Which bit of which drawing are you seeing an offset in?
My mistake. I thought that the cam bracket was the upper rod, which is in fact not seen in this view. :noidea:
Drooling over those engravings and the complexity of the machine.
One of you might be interested in https://www.abebooks.com/servlet/SearchResults?kn=delaby&sortby=17&tn=MACHINES+%C0+VAPEUR+
Gerrit
LOL, the drawing does take some digging through, doesn't it? That cut-off had us head-scratching for a while, as did the rear support bearing, although it has to be said i did ponder the option of mirroring the engine to put another two cylinders on the other side of the flywheel... :naughty:
Btw, thanks for the book links - now on order from Amazon! :happyreader:
Might castings be available to others? ;)
Wow, great project, it will be a treat for you to machine all these parts !
in addition to this sophisticated mechanics, not plain pieces of metal, but decorated, all of them !
brave man !
PJ - let me speak to Dennis and see how he feels about more sets. I had a sneaking suspicion that part of this project would be a full drawing pack instead of fag packet sketches... :facepalm:
Yup, it should be a great project, especially with the extra info - not fast if it's going to be done right, but the end result should be worth it! More SW on it tomorrow hopefully.
With the amount of detailed parts on that engine you would need a 100 a day habit to keep up the supply of fag packets :ShakeHead:
I meant to ask is there any progress on your full size engine?
Is this slated to be a team build, or everyone doing their own?
No, this one is everyone doing their own. I suspect there will be collaboration though, in that if someone is getting pieces laser cut, for example, it'd be nice to do a set for everyone.
Jason - I'm afraid to say I let it go. It was too heavy, too big, and the money & space liberated brought me a very nice little Kunzmann universal mill. It was a lovely thing, but right now it was just a bit too much :(
After months of merciless prodding :stickpoke: (which I needed anyway) I've joined my friend Dave and a few others in this build group.
It's a bit of a departure for me but it will a very interesting new challenge and model engineering adventure.
Thanks Dave! :cheers:
that sounds good, maybe an update of the state of play would be handy assuming some progress has been made in the last two years?
Some progress:
Looks beautiful Simon :praise2:
Is it welded together or :noidea:
At the moment it is just fitted together - the parts are really close fitting and there is quite a lot of interlocking. Plan will be to solder it as some point but I daren't do that yet as there is sure to be a need to take it apart for some reason.
Simon.
Should be a fun one to solder up. Is there a machining allowance so the critical surfaces can be skimmed after soldering or will mating parts be "adjusted" to suit?
Can you give an idea of the size of that assembly as I don't remember a scale being mentioned? I suppose anything will be a compromise between having it large enough to be able to model the small parts but being able to machine the large items such as the flywheel.
Dave, glad you started a thread on this build. It is going to be a beautiful model and fun build. Simon, thanks for posting your assembly, mine is still sitting on the desk in my den, the parts are beautiful as cut and the precision is amazing.
I am greatly impresses by all the comments and input from everyone so far. Every time I think I am starting to know a little about steam engines I read a column like this one and quickly get humbled by the knowledge freely shared by everyone else. Thank you all and I hope you continue commenting throughout the project.
Dennis
