Model Engine Maker
Engines => From Plans => Topic started by: jwcnc1911 on October 12, 2013, 02:14:05 AM
Hello all,
Apologies if this thread shows up multiple times... I have tried to post it 4 times over the last 10 hours. So if they all pop up at once, my bad.
I have started making chips on the little Stirling engine by Frank Arbeiter in his book "Drehen und Fräsen". You can find it here:
http://www.amazon.com/Drehen-Fr%C3%A4sen-Grundlagen-praktische-Anwendung/dp/3788306769/ref=sr_1_1?s=books&ie=UTF8&qid=1381539197&sr=1-1
It is my intention to actually do a build log and document every setup and step I take to make this engine. I hope it leads to some one buying the book and building one as well. Other than a few changes to make it suit my taste, it will be very close to the drawings. I will use ball bearings where possible, mine will be air cooled instead of the water resivoir, my material will be whatever I can find on the floor, and the flywheel will be different. It will have a very "De Waal" styled flywheel because I am a fan of Julius' work and I really like the larger diameter flywheels.
It is a very good looking engine with a unique linkage that is fun to watch. I have seen several good runners. Including one built by a friend of mine. You can see it here:
https://www.youtube.com/watch?v=MZURhtCgfaM
Harry has other videos of this little engine, all worth watching.
The first attached picture is a screenshot of the drawing to show the cutaway and side view of the engine.
The next string of pictures is what little start I've made on this engine. All I had time to do was cube the block. First, I machined 2in square stock down to size on four sides. That should be easy enough. This part is very small, so instead of dragging out an angle plate I used two V blocks in the Kurt vice to face the front and back nice and perpendicular to the sides. As soon as I pulled it out of the vice, I used a sharpie to mark it up clearly because it is not a perfect square.
Thanks for looking, I hope every one enjoys the build.
Hi JW,
I will certainly watch the build! I agree it's an attractive engine.
Hi JW, watching with great interest as long as I can understand :ThumbsUp:
Have you seen some of Rene Schaffers designs he has one that the power cylinder rotates
Stirling - Baukfastensystem ISBN 978 3 7883 2611 1 well worth the price £6.99p
cheers
That stirling runs incredibly smoothly! It's a joy to watch.
Simon
Thanks for the interest guys! I have been wanting to build this little engine for months! I refuse to have more than 3 projects going at once due to having a touch of OCD (means I start too much) coupled with the attention span of a goat (means i lose interest easily). It usually takes me a while to finalize a decision for a project but this one was an easy pick because I've had a chubby for it all the way through two other projects.
Hey all, I haven't had time fo work n mine but my friend sent me some pictures of his. The block of mine will be alu and the work cylinder will be bronze.
Hope you enjoy his pictures. Same one as in the video.
It makes me want to finish mine very vwry bad. Hope you enjoy the pictures like me.
The rest of the pictures.
What a very intriguing design. I really like the linkages too...far more motion than on many stirlings. Will look forward to your continued progress on it.
I agree with Bill, very interesting looking engine! I'll be following along on your build!
A very interesting engine!
JW-
Another example of your fine machining talents.
Interesting engine configuration, and, the convoluted linkages....even more interesting. Thanks for the sharing and photos.
Frank
