Author Topic: Swivelling Machine Vice from Hemingway-Kits  (Read 5396 times)
Offline Bruno Mueller
    • My Homepage
« on: October 18, 2020, 01:57:08 PM »
I have started a new project.
It shall become a vice. I found it at Hemingway in England and used the favorable exchange rate.
I ordered the material set and after a few days it was there.
Yesterday was the start. Part 1, I finished the base plate. The 360° graduation and the fitting of the pass strips are still missing, but they will be attached later.
First the cast blank was clamped onto the large face plate chuck and the bottom side was turned flat.
Then the center of the round casting shoulder was torn on the upper side. I did this with the centering angle. Again on the faceplate chuck this center was aligned and drilled, and the hole was turned out to 19.5mm and reamed with a 20mm reamer. The surface was turned so far that no casting skin was visible and the surface was smooth.
Now the 20 degree bevel could be turned. The inner heel was turned to the required depth and diameter. The center was supported with the rolling center punch and the top of the clamping flange was turned.
The groove for the clamping screws of the actual vice was cut to the required depth and width. For this purpose I ground a recessing steel from a broken off 6mm carbide cutter.
Now the part was taken to the milling machine and the outer contours of the clamping flange were machined.
Finally the mounting holes were torn and drilled. The positioning of the holes was based on the conditions of my milling machine table. My T-slots are 50mm apart.
In order to clamp the vice on the lathe (I have a groove distance of 75mm there), this dimension was also taken into account.
A 19mm hole to the groove was drilled from below.
Now I could clamp the base plate with a 20mm clamping bolt on the rotary table. Through the 19mm counter bore I could insert a T-slot milling cutter with 6mm shank from below and clamp it in the collet chuck of the milling machine and finish milling the T-slot.
« Last Edit: March 17, 2024, 06:10:13 PM by Bruno Mueller »
http://mueller-bruno.de/  http://www.bosch-combi.de/
Whoever talks shit about me behind my back is in the best position to lick my ass.
Greetings from the southwest of Germany.
    • My Homepage
Re: Swivelling Machine Vice from Hemingway-Kits
« Reply #1 on: October 18, 2020, 01:59:12 PM »
I have already pre-milled the actual vice. The dovetail for the movable jaw was already finished. I also milled the seat for the actual vice jaw.
The milling of the clamping plate and the outer contours is still missing.
The hole for the clamping nut will be machined later.
    • My Homepage
« Reply #2 on: October 18, 2020, 02:02:06 PM »
With the vice I have come further. The lower part of the vice is almost finished. The drillings for the spindle nut and the attachment of the top jaws are still missing.
I had to mill the dovetail again, the selfmade cutter had not shaped the corner properly. The corner radius of the insert was too large.
« Last Edit: October 18, 2020, 02:05:25 PM by Bruno Mueller »
    • My Homepage
« Reply #3 on: October 18, 2020, 02:06:58 PM »
And on it goes with the vice.
Today I have almost finished milling the movable jaw.
Dovetail is finished and fits.
Inner cutout for the spindle nut is fitting.
Outside contours, up to the final height and the jaw support is also made.
First I clamped the blank with the upper side (which was relatively straight and did not wobble) on the milling table.
As a stop I put a 12mm fitting strip into the rear guide groove of the milling table and clamped the blank with claws.
Now the underside of the vice was milled slightly and in the same clamping the sides were milled to a right angle up to 0.5 mm.
Now I could place the jaw on the underside and machine the upper side. Here I left about 1mm to the final dimension.
The jaw could now be clamped in the vice, which I had previously aligned exactly with the fine tracer.
The dovetail was next.
First only pre-milled and at the end the dovetail was milled with the HSS milling cutter. First of all only the side that does not get a positioning strip. This was tried again and again to see if it would fit on the vice.
After that the other side was on. Here also again and again try if the adjusting bar fits. A tenth of air does not matter. It is compensated with the adjusting bar.
Now the movable jaw was placed on its lower part and the sides were milled flush with the fixed jaw.
Then the cut-out for the spindle nut was made.
Still to be done, - the cutout for inserting the spindle nut.
- the hole for the spindle, as well as the holes for the set screws and the top .
Offline Chipswitheverything
« Reply #4 on: October 18, 2020, 02:25:42 PM »
Thanks, Bruno, for the photos and write up of this interesting project.  It is coming on very well, and may inspire other members to have a go at making this useful accessory.  Dave
Offline Johnmcc69
  • Erie Pa., USA
« Reply #5 on: October 18, 2020, 02:32:37 PM »
 :ThumbsUp:
Nice project!
    • My Homepage
« Reply #6 on: October 21, 2020, 03:50:35 PM »
After the dovetail guide was finished, the upper part was fitted.  I removed the guides only very slightly with a grinding file.
The movable jaw runs very easily and evenly.
I milled the complete vice again on the milling machine on the upper side so that the jaws are on the same level.
The height of the sliding plate is about 2mm higher, so it is possible to clamp wider pieces of sheet metal on the vice.
The thread of the spindle was pre-cut on the lathe and then the last hundredths were cut with a tread cutting dies.
The spindle runs in a bronze bushing.
    • My Homepage
« Reply #7 on: November 01, 2020, 09:39:45 AM »
Further progress.
The engraving of the 360° division was completed. That was a hard work.
Furthermore a milling for an adjustable zero line carrier was made. After the vice is exactly aligned on the milling machine, the zero line is finally applied.
    • My Homepage
« Reply #8 on: November 01, 2020, 09:43:04 AM »
more images
Online sco
« Reply #9 on: November 01, 2020, 11:05:19 AM »
Great work Bruno!
Time it earned it's keep now ;-)
Simon.
Ars longa, vita brevis.
« Reply #10 on: November 01, 2020, 05:26:58 PM »
Yes, I can see that took some time - but the time certainly paid off - it looks great!
    • My Homepage
« Reply #11 on: November 03, 2020, 11:42:05 AM »
The part is finished. The adjustable zero line carrier is attached and adjusted.
Now the question arises, should I still color the part or should I leave it like this?
What do you think.
I would have RAL 6011 available for selection.
    • My Homepage
« Reply #12 on: November 06, 2020, 08:28:58 AM »
I have now completely finished the vice. The fitting strips for the milling machine table were attached and also adequate clamping screws were made.
The vice was exactly adjusted on the milling machine with the fine tracer and the zero line carrier was aligned to position zero on the rotary plate.
Offline propforward
  • MN, USA
« Reply #13 on: November 06, 2020, 11:51:15 AM »
Lovely work. Not sure about painting it. It would certainly look good - but it already looks good in bare metal! Seems a shame to cover it up.
Forging ahead regardless.
    • My Homepage
« Reply #14 on: November 06, 2020, 01:35:07 PM »
The vice is now in place.
Adjusted and ready to work.
I will leave the vice like this. I think it looks so very good.
Offline propforward
  • MN, USA
« Reply #15 on: November 06, 2020, 02:11:41 PM »
Really excellent work. Very impressive! I agree, looks very fine in place, no paint needed.
« Reply #16 on: November 06, 2020, 02:34:15 PM »
That is an excellent machine vice, very useful I'm sure, and a very good photo write up, thank you.  ( You could always paint it at some later time if the fancy takes you, but it does look good as it is! )  Dave
« Reply #17 on: November 07, 2020, 06:48:11 AM »
I think it looks absolutely fabulous mounted there on your mill!  Beautiful work, you should be proud!
    • My Homepage
« Reply #18 on: November 07, 2020, 08:57:21 AM »
Thank you!
The production of the ring groove gave me some headaches.
A small note on the production of the T-slot.
Surely you can work it out with a hook chisel. I went a different way. I first cut the groove on the lathe from the top side. Then I drilled a 19mm clearance hole from the bottom side to the groove.
Now I was able to mill the groove with a Woodruff milling cutter that had approximately the same dimensions as the later groove.
I clamped the cutter with its 6mm shank from below through the 19mm clearance hole and the groove into a collet chuck.
With moderate speed and a lot of air cooling I could make the groove. But it did not fit in its height. The milling cutter only made a slot of 2,5mm and the width is not adjustable.
From China I ordered carbide T-slot cutters with the corresponding dimensions 1/2" x 1/4" x 5mm ; 6mm shank. When these were delivered, I re-milled the slot in the same way and brought it to a height of 5.5mm. The clamping bolts later have a height of 5mm and fit perfectly. These carbide cutters are actually intended for woodworking, but they also work in grey cast iron, but the speed and feed rate has to be adjusted.
« Last Edit: January 29, 2021, 01:11:19 PM by Bruno Mueller »
    • My Homepage
« Reply #19 on: April 04, 2023, 02:56:48 PM »
Hello friends.
I have given my vice a little paint.  I think he looks even prettier now.
Hammerite hammer finish was used.
« Reply #20 on: April 04, 2023, 05:33:57 PM »
Very sharp paint job!  Something to really be proud of  :ThumbsUp:
« Reply #21 on: April 04, 2023, 10:36:26 PM »
Looks really good Bruno  :ThumbsUp:
« Reply #22 on: April 05, 2023, 01:05:07 AM »
Nicely done, it looks great!
    • My Homepage
« Reply #23 on: April 05, 2023, 09:28:39 AM »
The zero-line carrier still has my new logo.
The knurled screw was also provided with the logo.
I had to make the clamping bolts for fastening to the turntable. The original material did not have enough strength and had stretched due to the tightening of the nuts.
I have now used tempered steel 42CrMo4.
Then the bolts were burnished.
« Last Edit: April 05, 2023, 09:41:48 AM by Bruno Mueller »
« Reply #24 on: April 05, 2023, 04:19:47 PM »
Awesome results she’s a beaut.    :Love:
    • My Homepage
« Reply #25 on: May 09, 2023, 04:56:55 PM »
I have secured the 0° and 90° positions with a dowel pin and two holes in the turntable.
    • My Homepage
« Reply #26 on: June 28, 2023, 09:31:19 AM »
The base plate of they vice also fits the VDH (versatile dividing head). I only had to make two additional clamping holes and a central receptacle for the centring pin of the screw hole in the base of the VDH.
I have also attached two zero-line carrier to the foot of the VDH.
« Last Edit: June 28, 2023, 09:41:33 AM by Bruno Mueller »
« Reply #27 on: June 29, 2023, 02:03:39 AM »
That’s awesome, I bought the swivel base for mine from Hemingway. Nice work….
