Quote from: Jo on August 30, 2020, 09:44:31 PMWe need the measurement from the centre of the crankshaft to the centre of the camshaft.38.537mm
As Jason has said 30DP seems to be close if you chose a 60 and 30 tooth gear (50.8 PCD and 25.4 PCD). This funny measurement term PCD (Pitch Circle Diameter) is not the outside diameter of the gear but the diameter at which the gears mesh.
As such an advocate of Metric I thought you would jump at the cance to use MOD?
Edit: A set of MOD 0.85 gears of 60/30 teeth gives a spacing of 38.2mm between shafts. I am not sure if these are common metric gear sizes. Jo
Quote from: Jo on August 31, 2020, 10:16:32 AMEdit: A set of MOD 0.85 gears of 60/30 teeth gives a spacing of 38.2mm between shafts. I am not sure if these are common metric gear sizes. JoThey are not which is the whole reason for using an idler in the first place as it allows 12/24T Mod 1 gears for crank & cam and can have it's own ctr position placed anywhere and also avoids having a massive 60T cam gear sticking out the side of the engine.
It's a lot better but the idler will need to be a whole number assuming MOD1 as at the moment you will end up with an odd number of teeth, is it possible to move No4 slightly to the left so the idler can be changed to 30PCD or further to the right so it can be 31PCD, this seems the easiest to move being just the distributor
