Author Topic: New enclosure project  (Read 6249 times)
Re: New enclosure project
« Reply #45 on: July 09, 2020, 07:01:00 AM »
Would it be easier to mount off the shelf sliding track at an angle, then just a simple angled cut to your wooden framing.
Also if you need to get the perspex out it is better to have a deeper top track so you can lift the panel upwards to free the bottom and take it out. If not you will need access from the end.
Online steamer
« Reply #46 on: July 09, 2020, 01:29:26 PM »
The tracks are Delrin Jason, and will screw in at assembly    There will be access from the ends through the windows..     Once I have the tracks where I want them they'll be screwed into the framing.   I'll look into cutting the top tracks deeper so that I can lift them out, but it's not necessarily a feature I want in the event of a broken cutter.
Online steamer
« Reply #47 on: July 09, 2020, 03:50:44 PM »
Got the files Dave Otto!
Thank you!!!!!!
Online Dave Otto
« Reply #48 on: July 09, 2020, 04:53:37 PM »
You are welcome!
Online steamer
« Reply #49 on: July 09, 2020, 07:43:45 PM »
Just found these extrusions....that'll work!
« Reply #50 on: July 09, 2020, 08:04:19 PM »
Hello Dave,
Could you use these or similar extrusions as the outer frame for you new cabinet. Just slip in the ply panels with a little glue. just think'in   :noidea:
« Reply #51 on: July 09, 2020, 08:19:11 PM »
Over here you can get PVC track which would screw to your timber framework, though you would need to source 6.35mm glass, best talk to Jo about that one!
https://www.ironmongerydirect.co.uk/product/chasmood-no-76-double-channel-2-metres-overall-height-127mm-width-1984mm-glass-size-635mm-812117
Also available as an aluminium extrusion.
Online steamer
« Reply #52 on: July 09, 2020, 09:09:05 PM »
Hello Dave,
I could, but I've cut the wood already.    Next step is to start the assembly....I may spend some time doing that but it's really hot today....we'll see
Online steamer
« Reply #53 on: July 09, 2020, 09:11:47 PM »
I got the aluminum, with black powder coat, on a while enclosure.   Should look good,  I need to recut the sills to fit the rails in, but that shouldn't be so hard
Online steamer
« Reply #54 on: July 09, 2020, 10:40:48 PM »
Rails cut...Im missing one more piece of plywood...and I'll have all the parts at least rough cut....did a quick update to the model for the rail
Online steamer
« Reply #55 on: July 10, 2020, 11:46:54 PM »
Final layout.... Now I have an accurate cut list...and dimensioned parts.     waiting on some material, but I'll start the build tomorrow I think....at least what I can
Supposed to rain like hell
Online steamer
« Reply #56 on: July 11, 2020, 06:19:49 PM »
Off to a good start   Front panel is together...and have started to work on the side panels.   I have a couple of panels to cut, but the lumber is done.
Glues and screws....should work very well.    I'll bondo any offensive bits, and put some fast drying urethane on.   and then a good healthy cote of Rustoleum white....
Online steamer
« Reply #57 on: July 11, 2020, 09:45:21 PM »
What I did find today was that a tray along the entire front of the machine is quite doable.  It doesn't restrict access to the mill in the least as long as it's fairly narrow    6 inch wide....so I'll change my design to allow for that.
Online steamer
« Reply #58 on: July 13, 2020, 12:54:32 AM »
Started to assemble and have it sitting in place.    It "feels good....top bar looks bent ...but it's actually straight....I checked it with a straight edge....
Window runners came today as well.
Online Dave Otto
« Reply #59 on: July 13, 2020, 01:00:11 AM »
Great progress Dave, looks nice!
