Author Topic: Plastic reduction gear set  (Read 3958 times)
Re: Plastic reduction gear set
« Reply #15 on: June 16, 2020, 05:19:03 PM »
You can't cut a 9 or 10 tooth gear with gear cutters  :-\
« Reply #16 on: June 16, 2020, 05:31:33 PM »
cut one with the rack method.....
« Reply #17 on: June 16, 2020, 05:35:56 PM »
Its a helical  :noidea:
« Reply #18 on: June 16, 2020, 05:51:41 PM »
http://modelenginenews.org/
Check out the feeny build log.   He makes skew bevel gears, but I see no reason why you couldn't use the same method to cut helical gears based on the results he had with this method....
« Reply #19 on: June 16, 2020, 06:22:46 PM »
Putting it in perspective: I can order the electric motor plus reduction gearbox for £16..... I'd like to find a cheap supply of just the gears.
« Reply #20 on: June 16, 2020, 06:27:16 PM »
 8)   I tried...…
« Reply #21 on: June 16, 2020, 09:13:50 PM »
How about 3D printing them  :embarassed:
« Reply #22 on: June 17, 2020, 07:12:40 AM »
I have considered this..... but they must be a stock item I just need to know the magic words for them to pop up on a search :noidea:
« Reply #23 on: June 17, 2020, 01:10:25 PM »
There is the RC car world, but I don't see them in Mod 0.5,      I do see them in 48 DP and 64 DP,   but the price is the same as  your commercial choices..
« Reply #24 on: June 17, 2020, 01:23:34 PM »
 :-\ Looks like I will have to order the entire assembly then.
In the meantime I will keep my eyes out they must be used somewhere else  :noidea:
« Reply #25 on: June 17, 2020, 01:24:11 PM »
This would be a cheaper option
« Reply #26 on: June 17, 2020, 01:33:28 PM »
Won't work  :disappointed:
Offline awake
« Reply #27 on: June 17, 2020, 08:22:35 PM »
Could I get the resolution needed for such small teeth on my 3D printer  :noidea:
Likely to be difficult to get the strength and resolution needed from an FDM printer. If you could get your hands on a resin printer, you might be in business!
Andy
Offline Mike R
  • Ottawa, ON
« Reply #28 on: June 18, 2020, 03:21:41 AM »
Which gear in particular is damaged?  the small pinion or the larger driven spur or both?  Would you be able to retrofit a metal pinion in place perhaps?
https://hobbyking.com/en_us/hobbykingtm-0-5m-hardened-steel-helicopter-pinion-gear-3-17mm-shaft-10t.html?queryID=83cadb5e650ff3d88450306880cf09d4&objectID=41263&indexName=hbk_live_magento_en_us_products
Offline Pete49
« Reply #29 on: June 18, 2020, 03:38:55 AM »
I would just hire a cleaner. No gears to break and easily replaceable. :ROFL: :lolb:
