Author Topic: Plastic reduction gear set  (Read 3983 times)
Re: Plastic reduction gear set
« Reply #45 on: June 19, 2020, 01:56:23 PM »
I've just tried printing a set and it looks like they will work... once I reset up the printer  :Doh: and fit the print head cooling fan that I purchased for it months ago  ::)
« Reply #46 on: June 19, 2020, 07:39:44 PM »
Do you have CAD? it would be fun run a few on our HP Multi Jet Fusion printer here at work.
« Reply #47 on: June 19, 2020, 08:11:42 PM »
I don't know what plastic materials Dave can offer with his(?) HP Multi Jet Fusion printer. Maybe Dave has some high strength material available. If not, provided the gear is the correct shape but not strong enough, you could get some printed by www. sculpteo. com or a similar print house, in one of their more exotic reinforced plastic materials
It may be another option
« Reply #48 on: June 19, 2020, 08:42:21 PM »
These would be solid Nylon PA12
« Reply #49 on: June 19, 2020, 08:52:53 PM »
Sounds like a good strong material to try.
« Reply #50 on: June 20, 2020, 06:21:56 AM »
These are the two stl files for the gears.
« Reply #51 on: June 20, 2020, 07:04:35 AM »
Can't see why the first gear could not be made from two pieces soldered together as it has straight cut gears.
Second one does not show any undercut of the pinion so again could have been cut and soldered to the skew gear.
« Reply #52 on: June 20, 2020, 07:12:14 AM »
Everything that has been made can be made again... it is all a case of how much time and effort you want to put into it  ::)
The ex-factory price for each gear is 10p each, the problem is minimum order 1000 plus £30 shipping  :toilet_claw: Last year I purchased two full assemblies, including the electric motors, for £6 each.
« Reply #53 on: June 25, 2020, 12:39:49 AM »
Here is a picture of the printed gears, not sure if they would work or not; they are pretty tiny.
The porous looking surface is only skin deep, under the gray is solid Nylon. This is caused by the transition between the part and powder bed that it is built in.
One thing is for sure I doubt that you would ever have much luck printing them on an FDM machine.
« Last Edit: June 25, 2020, 12:43:50 AM by Dave Otto »
« Reply #54 on: June 25, 2020, 05:37:35 AM »
They look rather good  :) Much better than I managed on my printer.
