That's a 3PH plug. How is the spindle speed controlled, if at all? Belts?
Quote from: kvom on June 07, 2020, 01:02:01 PMAny two of three leads of a 3P 220V will have 110V. Unless the plug wires go directly to the motor housing, I'd suspect that the electronics power is accommodated already. Should be obvious when you plug it in if the electronics are live.No - any ONE of the phases will measure around 100V TO NEUTRAL. The 230V refers to the voltage from one phase to another. Certainly, that should become obvious when (if) you plug it in like that(!)The simplest solution to running a VFD in a US house is to take the 110-0-110 feed from the breaker box and run the VFD between the 2 lives.
The formula is something like :Voltage between two Phases / Tan(-120 degrees) = Voltage between Phase and Neutral.
.... But then again - not much in the US makes much sense to me
