Chris:When you spin the crankshaft, do you make the required chuff-chuff sounds, or do the elves? You DO know the sound effects are mandatory don't you?Don
Hi Chris ,....just happend to see this on the web...........There's more than one way to skin a cat !!![youtube1]https://youtu.be/9sQzedI_Cw4[/youtube1]Willy
Does a 5 degree taper give the other engine parts 5 degrees of separation from the flywheel ? Hope this philosophical question doesn't make the elves' and Mr Ethan Oll's heads hurt after all those Elfensteiner stubbies yesterday.......
ChrisThanks for the explanation of the differences between the tractor and the five ton wagon.To be honest I have never delved that deeply into the differences in design and did not realise just how far apart they are.I bet that sliding eccentric would be tricky to pull off in a small model as well, much more sense to use something that we know will work anyway.Whatever you do it will be impressive I am sure.Phil
Quote from: pgp001 on November 15, 2020, 12:23:09 PMTrial steaming before Christmas ?PhilPossible but not very likely. Lots of little things, conrods, eccentric followers, piping, throttle, reverse gear and controls, to go still. Not to mention a two cylinder compound engine! Guessing more like late January or early February?
Chris has spoken. 5 spoken, in fact. Looking great!
