Unwrap it in your CAD program so it is flat sheet then print it out to use as a template then saw and file some sheet metal before rolling it back up and soldering into a ring.Alternative would be to run a gig say 10dp gear cutter across the end of a bar at say 12 divisions then bore out the middle and bend what is left outwards to a trumpet shape.
