Author Topic: Westbury Seal by Vixen  (Read 39732 times)
« on: May 04, 2020, 11:41:03 AM »
I've moved parts of the 'Seal Help' topic over to this new ' Westbury Seal by Vixen' topic.
« Last Edit: July 20, 2021, 07:03:57 AM by Vixen »
Re: Mike's Westbury Seal
« Reply #1 on: May 04, 2020, 11:45:46 AM »
 :pics:
« Reply #2 on: May 04, 2020, 02:17:04 PM »
Well you asked for some photos.
On the left is the billet of 6082 T6 I bought as an insurance policy in case the Hemingway casting did not arrive.
With the billet I get 6 potential datum flat surfaces, 12 potential datum edges and 8 potential datum corners to choose from. With the castings, nice thought they are, there is nothing flat or square or dimensionally accurate to measure from. I guess I am going to relearn all the old school marking out tricks.
« Last Edit: August 06, 2022, 09:07:35 AM by Vixen »
« Reply #3 on: May 04, 2020, 02:18:07 PM »
I measured up and created a three view drawing of the Hemingway casting, which I superimposed over my CAD model of the cylinder block. The casting external features were found to be generously oversize in most places. The internal cored feature, though difficult to measure, appear to be spot on for size.
I maneuvered the internal casting features to be a best fit on the CAD model. I find the upper water jacket area to need about 70 thou" removed from the top, side and end faces. The lower crankcase area needs something like  0.13" removed from both ends and approx 30 thou" from the sides. This will obviously machine off the raised flanges on both ends will disappear.  The bottom (Sump) face needs a massive 0.17" or so, to be removed. There are few parallel faces, even the four mounting lugs have a 5 degree draft angle.
There's a lot of material to remove. When I am finished almost every external surface will have been machined (I may as well have made it from the solid billet). I am considering leaving the lower crankcase oversize so as to have some cast features left.
I think my machining sequence will start with facing off the cylinder head top face slightly undersize and then to bring the water jacket ends and sides to the drawing dimensions. I then propose to finish bore the cylinders, valve pockets and all the stud holes, while everything is set up in this position. I can then use the machined  top and sides of the water jacket as datums for when I invert the casting to do the bottom face and mounting lugs. That should give me a nice square block to hold when I do the crankshaft and cam shaft bores on either end of the casting.
Well that's the plan. and as we all know, most plans will change after the first encounter with the enemy.
« Last Edit: August 06, 2022, 09:09:18 AM by Vixen »
« Reply #4 on: May 04, 2020, 02:19:00 PM »
Thanks to all of you for calling in. Good to hear you are all well.
Redrawing the engine in CAD gives a lot more freedom to make slight changes before the build. I have tried to incorporate all the valuable ideas and suggestions so generously provided by our MEM members. I have also read and reread the various build logs and the words of Westbury himself and fed in as many lessons as possible.
I made two big design decisions. First; the pistons should not protrude above the top of the cylinder block. Second; I decided to increase the cylinder bore and crankshaft throw in line with Westbury's suggestions while keeping the conrod length as designed. The engines displacement will now be closer to 20cc instead of 15 cc. Both changes require a slightly taller cylinder block. I also incorporated ChuckKey's advice to increase the tappet diameter to 9/32.
I only ordered the cylinder block and cylinder head castings, I plan to make all the other parts from bar stock as that gives me a little more flexibility to position thinks like the water cooling in/out lets to suite the Bren Carrier's installation. It also avoids the need to reposition bolt holes to fit the poorly positioned bosses of the castings.
First up, was to machine the upper half of the crankcase around the water jacket. I found that the valve gear pocket on the side of the casting was the feature which decided where the engine was positioned within the oversize casting. I set up the raw casting in my new (Christmas present to myself) machine vice, with the mounting lugs sitting on two steel rods acting as parallels. I selected a suitable datum from the drawing of the raw casting superimposed on by CAD drawing. I them machined the top face 0.04" overlength and the four sides of the water jacket to finished size. I now have five square faces and four edges to provide datums for all subsequent machining. You will notice the cast flanges on the water jacket  have been machined completely away. As Jason points out, that will provide greater flexibility for the plumbing.
The Aluminium alloy used for the castings appears to be of good quality and machines easily. I can tell it is softer then the T6 heat treatment normal with billet materials. I hope this softer alloy will not adversely effect it's ability to hold screws and studs.
I think it is about time to start a new build thread of my engine, which is separate from the 'Seal Help' thread.
« Last Edit: August 06, 2022, 09:10:38 AM by Vixen »
Offline gadabout
« Reply #5 on: May 04, 2020, 10:03:10 PM »
Mike,
My chair is pulled up ! Will be waiting eagerly for each update! Am looking very forward to the ride!
Mark
« Reply #6 on: May 04, 2020, 10:13:09 PM »
Hello Mark,
The cylinder block has been bored for the four cylinder sleeves and also for the eight valve guides and tappet guides.
Tomorrow, the next operation will be to drill and tap for the fifteen cylinder head studs and the five water passage holes.
When I have done all that, there will be so many holes in the top face, it's a wonder the cylinder head joint ever seals.
What do you recommend to use in place of a head gasket?
« Last Edit: August 06, 2022, 09:11:27 AM by Vixen »
« Reply #7 on: May 04, 2020, 10:31:13 PM »
Hi Mike
Many production model engines uses a simple trick, where the cylinder liner goes about 1mm into the cylinder head. This deals with the high pressure problem and in some cases there is a thin paper seal outside the liner to prevent oil leakage. So you have 1mm protruding above, that is also a bit bigger in outside diameter to the rest of the liner -> two bird with one stone - the liner is locked in position and is sealed at the same time.
I do not know if this is of any use here ...?
Looking forward to follow this build too  :cheers:    :popcorn:
Offline gadabout
« Reply #8 on: May 05, 2020, 01:22:25 AM »
Mike,
 I haven't used a head gasket on the advice of a Jo ( have you heard of her :lolb:)
I lapped the two surfaces on a surface plate and bunged them together , no problems so far! ETW did talk about some sort of varnish, can't remember the name atm
cheers
Mark
Offline gadabout
« Reply #9 on: May 05, 2020, 01:24:24 AM »
Mike,
Did you offset the cylinders 1/8" too
Mark
« Reply #10 on: May 05, 2020, 07:27:21 AM »
If I do need a gasket then I just give a thin smear of one of the liquid gaskets, small tubes easily got from Halfords in normal times but e-bay has plenty. iT does not add any height so no need to allow for that during construction.
Mike from the tooling showing in the latest photos I take it you used a boring path on the CNC rather than a boring head, do you also tap on the CNC or will that be manually done after CNC drilling?
Offline gadabout
« Reply #11 on: May 05, 2020, 08:16:13 AM »
Mike,
Copal varnish or Stags Wellseal were the recommended sealants for the block to head seal
Mark
« Reply #12 on: May 05, 2020, 10:50:02 AM »
Thanks Mark, Stags Wellseal, I remember reading about that but I lack instant recall these days.  :old:
Jason, Correct, I tend to use a boring toolpath whenever possible. My machine is accurate and produces a fine surface finish, better than I usually achieve with a boring head. I do turn cylinder bores on the lathe. I coordinate drill and tap the stud holes all at the same setting while still on the machine. The tap is held in a chuck loosely held in an ER collet. I have  quick change tool holders so changing between tapping drill and tap is quick and painless. I will add some photos of my set up latter.
Another question for everyone. The cam followers appear to fit directly into the aluminium cylinder block casting. The casting alloy is rather soft, so what is the life expectancy of this sliding fit? it cannot be very long!!!!   :headscratch:
Has anyone tried fitting bronze bushes for the cam follower/ tappet?
« Last Edit: August 06, 2022, 09:12:33 AM by Vixen »
« Reply #13 on: May 05, 2020, 11:38:41 AM »
All full size engines I've seen has the followers running directly in the aluhead - but they do have a lot more control over the Aluminium quality .... and only Kawasaki uses bearing "pans" for the camshaft in the head, when looking at motorcycles - but most cars I've seen (years ago) are like the Kwaker.
« Reply #14 on: May 05, 2020, 11:49:52 AM »
Hello Per,
If the cam follower was running in 6082 T6 alloy, I would have fewer concerns. The Hemingway casting is very soft and not heat treated in any way, also there is no posative lubrication to the valve chest. The question remains; Has anyone tried fitting bronze bushes for the cam follower?
« Last Edit: May 05, 2020, 12:40:25 PM by Vixen »
