Author Topic: 31/2" Tich  (Read 15437 times)
Offline samc88
Re: 31/2" Tich
« Reply #30 on: July 13, 2020, 04:13:04 PM »
I drilled the crank pins, typically I havent got a reamer so I've ordered one. I simply moved the mandrel to the drill vice and clamped everything down. This has resulted in holes in the same place in each wheel.
Since the 4 jaw is in the lathe I think I'll look at turning the eccentrics next (I'm edging towards doing the walschaerts valve gear but may make the slip eccentrics since I have enough material for practice)
Sent from my G3121 using Tapatalk
« Last Edit: August 07, 2021, 12:08:08 PM by samc88 »
Offline samc88
Re: 31/2" Tich
« Reply #31 on: July 13, 2020, 09:33:53 PM »
Cracking on with the running gear and got the pump eccentric machined other than cutting and facing to length tomorrow evening and running my reamer through it
The groove was cut with a stumpy grooving tool I have which works well in the mini lathe as it has no extra length to flex. I then marked out the axle centreline and used my wobbler to set the centre. First time using it (I usually use 2 dead centres and the dti) and it works well.
Really satisfying job
<a href="https://www.youtube.com/watch?v=vWLn6NFMBw8" target="_blank">http://www.youtube.com/watch?v=vWLn6NFMBw8</a>
« Last Edit: August 07, 2021, 12:08:54 PM by samc88 »
Offline samc88
Re: 31/2&quot; Tich
« Reply #32 on: July 14, 2020, 05:09:11 PM »
My 5/16" reamer came in the post today so did the wheel centres nd pressed one on each axle. Before this I took a fraction off the other end, my pan is to use loctite on the other end so I can get the quartering right. Being my first loco I didn't trust myself with pressing on both ends and keeping everything aligned, I should have leway with the loctite to get everything spot on whilst it's setting
« Last Edit: August 07, 2021, 12:09:16 PM by samc88 »
Offline samc88
Re: 31/2&quot; Tich
« Reply #33 on: July 15, 2020, 07:41:34 PM »
Finished the eccentric. Drilled and tapped for a 6BA grub screw, then used the rotary parting tool to cut to size before facing off to length and reaming to 3/8. Fits nicely on the axle, just need to get a grub screw for it
« Last Edit: August 07, 2021, 12:10:04 PM by samc88 »
Offline samc88
Re: 31/2&quot; Tich
« Reply #34 on: July 25, 2020, 02:13:56 PM »
Had my first go at making an eccentric strap yesterday. Looked complex at first but the way LBSC describes doing it is actually fairly straight forward. The only difference I did was to size the hole to the job (I rechecked the eccentric in the 4 jaw to have the groove running true, bolted the strap to it and tightened it until it started binding up, then using a feeler gauge in the open gap between the halves told me how much to take out of the eccentric, turned out to be 8thou to get a nice running fit).
 Pretty enjoyable thing to machine and really satisfying seeing it work when I test fitted to the axle. I'll mill the groove for the pump rod to be fitted later on as it means setting the vertical slide up and I'd rather do that when I have a couple of milling jobs to do to save set up time
My new Er32 collet chuck came in the post this week so might look at making the crank pins next to try it out. I also think it'll work better for lathe milling as it's more rigid than the other collet holder I have
« Last Edit: August 07, 2021, 12:11:20 PM by samc88 »
Re: 31/2" Tich
« Reply #35 on: July 25, 2020, 05:18:45 PM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn: lookin good!
Offline samc88
Re: 31/2&quot; Tich
« Reply #36 on: July 26, 2020, 08:07:57 PM »
Thanks cnr, I'm really enjoying this smaller side of engineering, quite a nice change from my normal job dealing with big stuff in boats.
Made a start on crank pins. First thing I did was to make the washers, I chucked up a piece of 3/8" mild steel, faced, centre drilled and drilled with a No. 41 drill then countersunk. Parted off to a thickness of 1/16" which went well.
Once that was done I started on the driving crank pin made from 1/4" silver steel (drill rod I think it's called over in the US). To start with I faced and turned down the spigot to fit in the wheel to the dimensions on the drawing, this led to the wheel being a slip fit on it, not ideal. Then i remembered I had some really small bore gauges and using them in the crank pin hole in the wheel I found my reamer cut the hole oversize. Not to worry. I started again and got a much better fit (1.5 thou over hole size so is a nice fit). The wheel is just starting to go on the end so should press together quite well I hope. Will part off and do the other one tomorrow.
I have some 3/16" silver steel in the post too to do the other pins.
« Last Edit: August 07, 2021, 12:12:10 PM by samc88 »
Offline samc88
Re: 31/2&quot; Tich
« Reply #37 on: July 28, 2020, 08:55:43 PM »
Not really done much a I've been sorting out my camping equipment for going away in the land rover this weekend. I did find time to finish off the first driving crank pin. Achieved a very nice light press fit in the end and went together well in the vice
I'll probably look at making the rest next week once I'm back, or I'll make a start tomorrow if I get time
« Last Edit: August 07, 2021, 12:12:35 PM by samc88 »
Offline samc88
Re: 31/2&quot; Tich
« Reply #38 on: September 06, 2020, 06:01:51 PM »
Getting back into this, had a lot of other things on in the background. Made up the leading crank pins today, first made a split Bush and turned the spigot to be a press fit in the wheel (2 thou interference fit pressed in nicely).
« Last Edit: August 07, 2021, 12:13:22 PM by samc88 »
Offline samc88
Re: 31/2&quot; Tich
« Reply #39 on: September 06, 2020, 07:42:30 PM »
I also remade the drvng pins as I was t happy with them, this time I used a piece of steel drilled and reamed to 3/16 as a gauge and I'm much happier with them
« Last Edit: August 07, 2021, 12:13:49 PM by samc88 »
Offline samc88
Re: 31/2&quot; Tich
« Reply #40 on: September 13, 2020, 08:08:36 PM »
Got into gear and started on redoing the axle boxes, I wasn't happy with my first attempt and decided to go about it in a different way this time. I basically, squared off the end of the casting stick and cut it into 4. Then using the side of the end I'll I machined all 4 to length, then to width, before machining the centre portion and the flange. Got two finished today and pleased with how they've come out, they fit nicely in the hornblocks, I think I'll do a light lap to get them running really smoothly. Looks like the wheels will have minimum side to side play too when I fit the axles
« Last Edit: August 07, 2021, 12:14:13 PM by samc88 »
Offline samc88
Re: 31/2&quot; Tich
« Reply #41 on: September 14, 2020, 09:22:17 PM »
All four are now machined to size and stamped with their location. I have pilot drilled them for the axles but my phone ran out of charge to take a photo. My pillar drill won't run slow enough to do a good hole for the axles so I'm going to drill them and ream them in the lathe using the 4 jaw. I'm quite pleased how these have come out considering the mini lathe isn't the most rigid of things for milling on
« Last Edit: August 07, 2021, 12:14:41 PM by samc88 »
Offline samc88
Re: 31/2&quot; Tich
« Reply #42 on: September 15, 2020, 08:08:17 PM »
 :DrinkPint:I drilled the axle hole in the lathe with the 4 jaw. These appear to line up nicely with each other. I thought I had a 3/8 reamer but it was not to be so I settled for drilling the spring pockets. I did originally drill an oil hole in the middle but then learnt that this wouldn't work properly for the oil film in the axle box so I blanked off the middle hole and drilled through the spring pockets into the side of the axle bore. Quite happy how these have turned out, I hope to have a rolling chassis by the weekend if the reamer comes soon.
« Last Edit: August 07, 2021, 12:15:39 PM by samc88 »
Offline samc88
Re: 31/2&quot; Tich
« Reply #43 on: September 15, 2020, 09:42:59 PM »
Found a reamer, it was cunningly hidden in the box marked reamers. Needs a little bit of fettling to get everything running smoothly as I made the axle boxes to be a good fit in the hornblocks, nothing a few strokes with a file won't sort out.
Also quartered the wheels on the leading axle using a method described by LBSC in the build articles, using a square across the centreline of the axle and the crank pin and a height gauge set to the axle centerline. This is done with loctite so I have some leeway
Re: 31/2" Tich
« Reply #44 on: September 16, 2020, 11:04:07 AM »
A rolling chassis - congratulations on reaching the first milestone  :cheers:
