Author Topic: 31/2" Tich  (Read 15421 times)
Re: 31/2" Tich
« Reply #15 on: April 19, 2020, 06:02:54 PM »
Interesting to see a milling attachment used on the lathe, likely the way LSBC did it.  I know that the Westbury paddle engine I built was done that way in the 50s.
Offline GWRdriver
  • Tennessee USA
Re: 31/2" Tich
« Reply #16 on: April 19, 2020, 06:10:28 PM »
I built a 71/4 inch gauge version of TICH many years ago, [snip] Perhaps others have a view on this. - Trevorc
I will eventually get to my point and in the meantime my apologies for semi-hijacking samc88's thread, which I'm also following with interest.
I have a 2X (7.5"ga) TICH under construction but I changed a number of frame dimensions to accommodate larger drivers so the original valve gear drawing (adapted from LBSC's 3.5"ga by Harry or Chas Kennion) won't apply to my chassis.  I have to do my gear from scratch, and it's giving me fits, but in all fairness to the gear I've yet to sit down with a saucer of biscuits and a full pot a' and wrestle it into submission.
I've also learned that valve gears are a particular source of errors, innocently made perhaps, but never corrected despite being widely found.  My first mentor, a meticulous builder, embarked upon an LBSC MABEL only to find a major error in the rocking linkage location which required remaking most of the valve train.  He was not pleased, and I've come to view valve gear designs through very squinty eyes.   :Lol:
It would therefore be wise to make your own check on valve gear dimensions.
If you're not already familiar with them, the Dockstader valve gear programs are excellent for just that.  Dockstader is not a "design" program per se, although it can certainly be a valuable tool in helping develop your own gear design or adapting one, rather it's intended to be a testing tool, which will give you an animated picture and report of the events of a given gear design.
Running the basic TICH gear through Dockstader won't necessarily expose "errors", but it will show how the gear as-designed behaves and will tell you where improvements in events can be made, if you want to make them.
Cheers,
Harry
Online samc88
Re: 31/2" Tich
« Reply #17 on: April 19, 2020, 09:06:20 PM »
Thanks for the information on the valve gear. Shall definitely bear that in mind when I come round to it, I think I'll be doing the Walschearts mechanism as to me it looks better than the slip eccentric. Don't consider it hijacking the thread, it's all good to know!
Kvom, yes the vertical slide is handy but when I move to my new place a small mill is definitely on the cards
Sent from my G3121 using Tapatalk
Online samc88
Re: 31/2" Tich
« Reply #18 on: April 19, 2020, 09:12:55 PM »
After playing around with the land rovers this morning pulling my brothers 90 forward in the garage with my 88 I set about on this for a bit more work
First off I drilled the brackets for 7BA bolts and did another assembly. I'm using hex heads rather than cheese head bolts as they just look better to me (also I already have some to hand)
Next I machined the axle box rebate to use as a gauge for opening out the hornblocks. This was an interesting thing to work out but got there in the end once I took the splash guard off, not the most rigid set up but with light cuts it worked well, just have to finish the corners by hand as I don't have a cutter long enough. Axle box is a snug fit so with some final fettling by hand it should all run smoothly.
Online samc88
Re: 31/2" Tich
« Reply #19 on: April 20, 2020, 02:33:47 PM »
Finished off the hornblocks and bolted up the frames. Also machined the pump stay at both ends to be a nice fit between the frames
Re: 31/2" Tich
« Reply #20 on: April 20, 2020, 04:22:45 PM »
Rolling right along!   :popcorn: :popcorn: :popcorn:
Online samc88
Re: 31/2" Tich
« Reply #21 on: April 23, 2020, 09:31:40 PM »
Not a great deal to report, been busy with other things but got the time today to square up the second pair of axle boxes ready for final machining to size and tidied up the workbench and toolbox
« Last Edit: August 07, 2021, 12:16:33 PM by samc88 »
Online samc88
Re: 31/2" Tich
« Reply #22 on: April 24, 2020, 07:33:22 PM »
Bit more axlebox progress, machined the sides of the second pair so they're a snug fit which is what I wanted, means I can finish them both to a nice fit now, only needs a couple of thou coming off the side to go up and down freely I think. Once that's done I'll machine the other faces. The frames are black as I had a bit left after I was painting my garden roller so just put a thin coat on to protect it a bit
Also shown is my milling set up and how I can accurately set my Z axis which is now going along the lathe bad rather than up and down on a conventional machine. I took a gear out of the change gear train at the headstock end so the leadscrew is free to rotate, I then lock the half nuts and wind the lead screw with a 10mm spanner which moves the carriage left and right (into or away from the cutter). Eventually I'll actually make a proper hand wheel for the lead screw
Offline MJM460
Re: 31/2" Tich
« Reply #23 on: April 24, 2020, 11:53:31 PM »
Hi Sam, you are making great progress.
That is a very nice vertical slide for your lathe, I can see why it works so well.  I have not seen one like that before, perhaps I was not looking very hard.  Good idea on the lead screw too.  The one I bought had provision to rotate the slide and around an axis parallel to the lathe axis, which, while it might have had some extra functionality, made the support very flexible, so it did not work so well.  Nothing like the rigid mounting yours has.  Probably why I never found it very satisfactory.
Online samc88
Re: 31/2" Tich
« Reply #24 on: July 06, 2020, 09:22:33 PM »
The saga continues.
Now I've verified my lathe and had more experimentation with milling now that the spindle doesnt have a good few thou of play in it, I thought I'd carry on with the axle boxes. Set up the slide tonight and started by squaring up the end of the casting stick.
I'll square the other end tomorrow and then cut it into the individual axle boxes for the further lathe operations. Ideally I'd mill each pair together but it's pushing the travel a bit which was my issue before. Must be set up properly as the axle bix is surprisingly square
Online samc88
Re: 31/2" Tich
« Reply #25 on: July 06, 2020, 09:23:51 PM »
I also think I'll invest in an MT3 milling cutter holder. I've a feeling it'll be more rigid than the current collet set up which sticks out a bit
Online samc88
Re: 31/2" Tich
« Reply #26 on: July 12, 2020, 05:40:55 PM »
Change of plan. I had a turning job to do and I cba setting up the vertical slide again so decided to do some lathe jobs which I enjoy more at the minute. Mini mill is on the cards when I move house.
Anyway, I've made up the pair of axles. I've added a decorative centre either end just so it looks like it's been turned between centres similar to a full size one. They came out really well and bang on dimension. I've turned the end to be 1 thou over 5/16 to be an interference fit with the wheels. Investing in a mag back dti has made a huge difference to easily making shoulders to identical lengths (I haven't got a carriage stop for this)
Online samc88
Re: 31/2" Tich
« Reply #27 on: July 12, 2020, 06:26:21 PM »
Also made a start on the wheels, faced the back and drilled the centre 19/64. I've got a hand reamerbon order to do the final size later. I haven't the clearance in the lathe to turn the OD of the flange as LBSC writes in the articles on doing this so I'll make a mandrel to fit in the centre hole.
Online samc88
Re: 31/2" Tich
« Reply #28 on: July 12, 2020, 10:24:19 PM »
I got carried away as the cast iron castings machined beautifully. The mini lathe handled 20 thou deep cuts in it really well.
I flipped the wheels around in the chuck and machined the boss and rim face. I took 10 thou off the edge of the wheel then using my depth gauge I took the boss down to required size (0.031" proud). Once that was done, I flipped the wheels round again and took the total width down to a total of 3/8".
To machine the outer diameters I made an aluminium mandrel and threaded it M6 and clamped it with an M6 bolt and penny washers. I did originally use normal flat washers but they didn't offer much grip and the blank did spin with the interrupted cut so I found some penny washers and they worked out much better.
 One wheel is finished other than reaming the axle hole and then drilling the crank pin hole. All in all its been quite a successful afternoon
« Last Edit: August 07, 2021, 12:17:53 PM by samc88 »
Online samc88
Re: 31/2" Tich
« Reply #29 on: July 13, 2020, 01:34:53 PM »
4 wheels now machined to size. With that done I marked the location for the crank pin. To do this I put a sharp tool in the tool holder and set it over on the centreline of the lathe, then I pulled it back by 9/16" and marked the hole centre
« Last Edit: August 07, 2021, 12:18:23 PM by samc88 »
