Quote from: zeeprogrammer on April 09, 2020, 10:22:56 PMYou mentioned 'boring' in a previous post. What did you use? The boring tool from Sherline?I used that for a couple of holes and (like Bill mentioned) found it difficult to adjust accurately.I got it done (despite ruining a parallel in the process) but the holes ended up just slightly larger than the bearings.My mistake was making the bearings first. I should have made the holes and then turned the bearings to fit.BTW Where's the elves? Are they quarantined? As they should have been years ago. I also have had issues with the sherline boring head, works but sometimes it is tough to get a close final size since it just pushes in one direction with the dial and tightening the locking screw can shift things. Recently I picked up a APT head, which is larger, has a tension adjustment on the slider, and a better dial. It does not fit the headstock threads so I had to make an adapter using a sherline blank mill holder. One thing you should do is stop a bit short of final diameter and do an extra pass or two at one setting, it will take off a little more metal, due to the spring in the cutter. Then remeasure and adjust in very slightly, repeat as needed.Oh, and the elves have locked themselves in big ziplock bags, muttering something about 'dont know where you have been'.
Quote from: crueby on April 09, 2020, 10:51:16 PMQuote from: zeeprogrammer on April 09, 2020, 10:22:56 PMYou mentioned 'boring' in a previous post. What did you use? The boring tool from Sherline?I used that for a couple of holes and (like Bill mentioned) found it difficult to adjust accurately.I got it done (despite ruining a parallel in the process) but the holes ended up just slightly larger than the bearings.My mistake was making the bearings first. I should have made the holes and then turned the bearings to fit.BTW Where's the elves? Are they quarantined? As they should have been years ago. I also have had issues with the sherline boring head, works but sometimes it is tough to get a close final size since it just pushes in one direction with the dial and tightening the locking screw can shift things. Recently I picked up a APT head, which is larger, has a tension adjustment on the slider, and a better dial. It does not fit the headstock threads so I had to make an adapter using a sherline blank mill holder. One thing you should do is stop a bit short of final diameter and do an extra pass or two at one setting, it will take off a little more metal, due to the spring in the cutter. Then remeasure and adjust in very slightly, repeat as needed.Oh, and the elves have locked themselves in big ziplock bags, muttering something about 'dont know where you have been'.You do know you can pop those bags just like popping paper ones, eh? That'll wake 'em up, and they may not be doing too much more muttering - 'specially with all that 'boring' work going on!
:popcornI wondered what that tap tap tap tapping sound was - now I know it was Chris tapping!
I had one that was attacking itself in my truck mirrors,, had to cover them large sweat socks when I parked at home,, hang an owl picture in the window..
Great work Chris. That sprocket on the table looks just like a Tiger 1 sprocket.Vince
