Looking to buy a lathe to get into making my first small engine . I would like a small lathe (7x 8x 9x) that can be used for other work as well, and capable of accurately cutting, threading and drilling steel.I have been doing extensive internet research, and I am still not very far along in making a decision. One of the factors is starting out inexpensively in case I don't really stick with the hobby. Yet, I am concerned that I will be too quickly unsatisfied, and want a better more expensive small lathe in the same size range. Shop space is a consideration. I have been looking at the Microlux 7x16, the Seig C3, Harbor Freight 7x12 and 7x10, Grizzly lathes, and the Little Machine Shop Hi torque 8.5 x 20 which may similar to the Seig SC4. Help would be appreciated.
Zeeprogramer, are there any beginner engines (I thought I saw some) that one could do without a mill, or maybe do with a lathe milling attachment?Also, you are absolutely correct as to what you want to build may change. That is one of the factors that makes the decision so difficult.Thank you.
I do not yet have any [larger] machines [lathe & mill], however you may find interesting, the size of components that can be achieved on relatively small machines..This link to the latest build by member Chris is below, although his previous build threads are an absolute inspiration to many model engineers, and again an appreciation of sizing the mill & lathe used by Chris http://www.modelenginemaker.com/index.php/topic,9468.msg216110/topicseen.html#new[My wish list is a Sieg SC3/400 lathe .......I would also love the small SX1L Seig mill]......may colleagues have suggested both are too smallSo many nights & ........ Derek
...What is nice about this hobby, there are machines and engines for all levels. I started out simple and have been working my way up from there. The most important tool for the hobby is your mind. Once you develop an understanding of the basics, you can literally make anything, if you put your mind to it. -Bob
Quote from: 90LX_Notch on March 12, 2020, 12:30:45 AM...What is nice about this hobby, there are machines and engines for all levels. I started out simple and have been working my way up from there. The most important tool for the hobby is your mind. Once you develop an understanding of the basics, you can literally make anything, if you put your mind to it. -BobWell said!
