Remember the bent out shape frame? It's coming back to haunt me.
Thanks for the kind words Tom. You are really at the mercy of the castings. Machining parts from clean, smooth brasss rod can be fully appreciated after you have worked with some of these 'rubber mold' cast white metal parts.Hi Per,Well, to be honest, I've composted some of the shots so that the blaring misfits in the crank area are not noticed. Some of the little 00-90 threaded cast bolts were so soft, they broke off when I tried to thread on a brass nut. But as I said, the overall impression from a viewing distance of about 2 ft. of the total finished model will be impressive (I hope).
