Author Topic: Bond's "Simplex" Petrol Engine  (Read 27241 times)
Offline ths
Re: Bond's "Simplex" Petrol Engine
« Reply #15 on: November 12, 2012, 10:37:42 AM »
I'll join Lee and Rick in the jealousy seats, and no, I can't guess what you're making on the shaper.
Hugh.
Online Jasonb
« Reply #16 on: November 12, 2012, 12:28:58 PM »
This is comming along nicely, I would say you are making a fixture to hold the cylinder head so that the valve guides and seats can be machined in the lathe in the same way a sthis
Offline pgp001
  • West Yorkshire - UK
« Reply #17 on: November 13, 2012, 08:21:40 AM »
A bit too easy that one.
Here it is on various machining setups for the cylinder head.
Phil
« Reply #18 on: November 13, 2012, 10:32:05 AM »
That tilt swivel tabel sure comes in handy.....one of the very few accessories I'm missing on the F1.
Offline ths
« Reply #19 on: November 13, 2012, 12:34:29 PM »
Phil, I take it that the milling machine is an Aciera. Is that an F3?
Hugh.
Offline pgp001
« Reply #20 on: November 14, 2012, 07:54:50 AM »
Hi
The milling machine is an "Alexander Master toolmaker", it is the British version of a Deckel FP1.
It comes with loads of gadgets like slotting head, dividing head & high speed head etc.
There is not much you cannot do with it.
http://www.lathes.co.uk/alexander/index.html
My dad restored it before he died, and rigged it up as a Sunderland gear shaper for making Myford changewheels.
He was a bit of a gear boffin was my dad, I bet not many people could figure out a gear train like this.
Phil
« Last Edit: April 13, 2013, 11:39:30 PM by pgp001 »
Offline Bezalel
  • - Skype:Bezalel2000
« Reply #21 on: November 14, 2012, 10:53:59 AM »
Yeah! I recon the book of change wheel tables would weigh nearly as mutch as the gear set   :Jester:
Queensland - wet one day, humid the next
Offline pgp001
« Reply #22 on: November 16, 2012, 10:41:08 PM »
Here's a few of the connecting rod.
More to follow in due course.
Phil
Offline sbwhart
  • Live Long and Prosper
« Reply #23 on: November 17, 2012, 08:13:34 AM »
Some nice set up shots
Some nice machinery
Some great work
Keep them comming Phil
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :ThumbsUp:
Stew
« Reply #24 on: November 17, 2012, 11:07:38 AM »
I like the rotary table set up!   Simple and effective!
Offline ScroungerLee
« Reply #25 on: November 17, 2012, 12:34:19 PM »
Good pics, they make your process very easy to understand, thank you!
Lee
Mmmmm.... Shiny!
Offline pgp001
« Reply #26 on: November 19, 2012, 10:53:03 PM »
Here is the job I have been looking forwards to least of all, the rockers.
I started with a couple of discs
Ball ended slot drill to make the pocket for the pushrod bucket.
Picking up the centre line with a laser centre finder.
A bit more shaping by milling out the undersides.
Almost there, just a bit more fine tuning with the file before fitting the ends
Ball turning tool set up for making the pushrod buckets, I used silver steel for those. (drill rod)
A bit closer in
After silver soldering all the bits together.
A trial asembly.
Al the other bits finished and assembled on the head.
Phil
« Last Edit: November 19, 2012, 11:03:46 PM by pgp001 »
Offline Bezalel
« Reply #27 on: November 19, 2012, 11:25:12 PM »
Nice work Phil !!
Are the ends of the rockers hardened?
Or is the air cooling adequately quick, after silver soldering, to make them hard?
Bez
« Reply #28 on: November 20, 2012, 02:15:30 AM »
Excellent work on the head Phil. Great fabrication on the rocker arms.
« Reply #29 on: November 20, 2012, 07:19:29 AM »
You made that look nice and easy. I will give it a go on my R&B.
