Author Topic: Different engine configuration  (Read 1775 times)
« on: February 25, 2020, 01:47:49 PM »
Has anyone seen an i.c. engine which operates with the crankshaft being driven by a "Bell Crank"? The closest I have seen to this is the Rockerblock engine which I designed and built a few years ago. I'm casting about looking for a new engine to design and build, and I don't remember seeing this configuration before.---Brian
Re: Different engine configuration
« Reply #1 on: February 25, 2020, 03:05:59 PM »
I recall seeing them on sterling engines, never on IC or steam ones. With a pair of them you could do a horizontally opposed engine with an offset crankshaft. Or with both facing up a U-shaped engine rather than a V-shape. Interesting concept!
Online Jasonb
« Reply #2 on: February 25, 2020, 03:38:31 PM »
Why not try one with an "Evans beam" like on my Woody as that would put teh flywheel where your newly welded fan blade spokes would cool the head and top of the cylinder to best effect.
Offline AVTUR
  • West of England
« Reply #3 on: February 25, 2020, 04:48:22 PM »
Wooler, in the UK, made a small batch of 500cc motorcycles after WW2 using his own engines. One of his two 4 cylinder engines had opposing cylinders transverse mount, one pair above the other. The pistons drove a single crankshaft through, what he called, a rocking beam.
I believe the Science Museum has an engine. Certainly the book they published many years ago, "Motor Cycles, a technical history" by C F Caunter, gives an inventory number of 1952-301.
I have managed to find a sketch of the arrangement which is attached.
AVTUR
« Reply #4 on: February 25, 2020, 05:05:09 PM »
AVTUR
That is a particularly interesting engine configuration. Looks like it could tick many of the boxes. :thinking: :thinking:
It has a lot in common with Dieters patent engine. The Wooler is an H configuration while Dieter uses a four in line configuration
AVGAS
« Last Edit: February 25, 2020, 05:12:12 PM by Vixen »
Offline Alyn Foundry
« Reply #5 on: February 25, 2020, 05:08:24 PM »
Possibly....
Andrew of Stockport Bisschop .
Offline Allen Smithee
  • Mordor, Middle Earth
« Reply #6 on: February 25, 2020, 05:34:47 PM »
How about an axial, parallel cylinder engine like the Aerial 35?
PDR
Offline Bluechip
  • Derbyshire
« Reply #7 on: February 25, 2020, 06:53:43 PM »
I vaguely remember reading a book with some novel engine layouts.  :old:  :headscratch:
POSSIBLY this:
https://www.amazon.co.uk/Knife-Fork-Man-Charles-Benjamin/dp/0955445507
OR NOT.
Anyone else know?
Offline AVTUR
  • West of England
« Reply #8 on: February 25, 2020, 07:05:31 PM »
A book I never managed to buy many years ago was "Some unusual engines" by L J K Setright. A friend had a copy which I frequently borrowed (and returned).
Amazon will sell you a second hand copy for £88!  :facepalm:
AVTUR
« Reply #9 on: February 25, 2020, 10:26:21 PM »
I have a few new things going on. Biggest new thing is that I just bought a tig welder. A tig welder will let me fabricate vaned flywheels. If I take the Rockerblock concept and rotate it until the cylinder sets vertically, then I can almost fit an air cooled cylinder directly in the flow of air from the vaned flywheel.
« Reply #10 on: February 25, 2020, 11:18:54 PM »
Jason--Tell me more about Evans Beam and your Woody.
« Reply #11 on: February 26, 2020, 12:02:32 AM »
Brian,
In the picture you show the link on the crank end should be at the centerline of the crank and with the piston at BDC the crank pin should be at TDC.
« Reply #12 on: February 26, 2020, 12:19:16 AM »
Thanks George--I know that. Again, this is just hypothetical layout stuff. Trying to see what configuration works best in terms of small footprint and getting the cylinders cooling fins into the air stream from the vaned flywheel.---Brian
Online Jasonb
« Reply #13 on: February 26, 2020, 07:21:35 AM »
Brian, have a look at this thread, as you can see from the first photo the flywheel is ideally placed to cool the head and top of the cylinder. That flywheel is about 5" so your 6" one would either cool the cylinder more or give a bit more room around the head for valves. Least cluttered option would be atmospheric inlet so no cam or rockers needed, sparkplug in from the edge of the head or at least towards the top half of the cylinder, camshaft could be above the crank with simple pushrod direct to exhaust valve, as an alternative it would really suit an epicyclic gearbox on the crankshaft with the eccentric cam operating directly on the valve.
http://www.modelenginemaker.com/index.php/topic,9126.0.html
Online sco
« Reply #14 on: February 26, 2020, 12:40:07 PM »
What about Scotch yoke with variable stroke?
http://www.freepatentsonline.com/4485768.html
Simon.
Ars longa, vita brevis.
