See, being forced to stay at home can have some benefits? Maybe?
Quote from: crueby on February 24, 2020, 06:30:56 PMThe body of the post is just aluminum, so it drills/taps very easy.I got my QCTP from LMS. According to their product documentation, it's all steel construction.I don't know if it's been treated to make it hard or not.I can always give it a try and see what happens.
You are using the lock on the z axis, right?
When lowering the headstock, always go past and raise back up to the spot you want.
When lowering the headstock, always go past and raise back up to the spot you want. Between the backlash and how tight the gib is, its the only way to be sure of the position. You are using the lock on the z axis, right?
Still feeling foolish. I'm having to go back to 1st grade and have a couple of questions...1) Let's say I'm milling a pocket. How does the process of lowering past target and then back up work? Can't go past. What I've done is touch off a piece of paper and then plunge to depth.2) On my PM25 mill, I've typically used the fine Z control to move the quill to depth (after using the big Z knob to get near the target). Does the same process apply? As I recall, there was resistance when moving down to target but significant play when I raised it.
