Jo are the DA collets like 5C and MT being a fixed size?
Read too many people with problems getting direct fit ER chucks to run true which would put me off that way of mounting them, at least with a backplate you can make it to suit the individual machine.
Other than Colin at Cowells is there anyone else supplying M14x1 threaded DA200 collet chucks.
Inserting the cutting tool less than 2/3 the gripping length into the collet can permanent damage the colletFull length of the gripping bore must be maintained to achieve accuracy and safety
2/3rds of the gripping length on some collets is much shorter than the length of the collet
Well I suppose when the Cowells was first about none of us had heard of ER collets so the DA ones are a bit dated and makes sense to update to what is easily available
