Author Topic: Breisch Duplex Steam Pump  (Read 402 times)
Offline Rod999
« on: February 10, 2020, 10:51:26 PM »
I won't be posting a build thread but just show some of the work involved, it might be a little slow, but with any luck it will pump someday~  This is boring the steam cylinder~
Re: Breisch Duplex Steam Pump
« Reply #1 on: February 11, 2020, 08:19:24 AM »
Rod how did you decide to make sure you got the spacing between the bores on both the steam cylinders and the water pumping cyclinders identical?
Offline Rod999
« Reply #2 on: February 11, 2020, 12:38:44 PM »
         I did the pump end in the horizontal mill with a DRO reading to a tenth, but it's too hard to see what's going on with that set-up. This above photo is a P&W 1E jig borer reads to a tenth and I squared the set-up down to a tenth before clamping.
