Author Topic: Gloat  (Read 5646 times)
Re: Gloat
« Reply #15 on: February 08, 2020, 06:10:29 PM »
Check the emergency stop button, some need to be turned so pop out to arm them
« Last Edit: February 08, 2020, 06:14:51 PM by Jasonb »
Offline Bluechip
  • Derbyshire
Re: Gloat
« Reply #16 on: February 08, 2020, 06:25:14 PM »
Nope/ Not this one.
E-stop locked down = No Power
Twist it, red button pops up, fan starts, tach says 0 rpm and there seems to be a quiet buzz ... maybe a transformer or possibly an AC contactor coil .... dunno.
There is a a ( revised ? ) schematic stuck to the back of the machine. Just done a piccy of it.
The diag, in the manual is b*****cks. WRONG !!!   :D
Your edited version is correct .....   :ThumbsUp:
Re: Gloat
« Reply #17 on: February 08, 2020, 06:46:24 PM »
I hope you have not had any  :wine1: if you are messing around with your new toy  ::)
Who was it telling me the other day about a friend's kid going into his workshop and hitting all the stop buttons on the machine tools?  :noidea:
Offline Bluechip
  • Derbyshire
Re: Gloat
« Reply #18 on: February 08, 2020, 06:54:32 PM »
Hi Jo
No. Just come in to sulk .... No fingers or any other body parts were shoved into the 'lekkery bits.
I am about to have a shower then settle down to a couple of  :DrinkPint:
It'll still be there tomorrow.
Re: Gloat
« Reply #19 on: February 08, 2020, 07:04:28 PM »
Does the forward/reverse switch have a central 'o' position?  ::)
Offline Bluechip
  • Derbyshire
Re: Gloat
« Reply #20 on: February 08, 2020, 07:18:11 PM »
Yes.
Set to 'F'  .... no go there or on 'R'
Offline Bluechip
  • Derbyshire
Re: Back to Gloat
« Reply #21 on: February 09, 2020, 07:57:34 AM »
Fickstit.
Operating wotsit on belt / gear cover loose.  Just as Zee predicted .....  ;D
Whizzes round quite happily now .... except ...
The gear train is abominably noisy  :(
Which seems to be a common experience ....  :ShakeHead:
Onward and upward.
« Last Edit: February 09, 2020, 08:48:08 AM by Bluechip »
Re: Back to Gloat
« Reply #22 on: February 09, 2020, 08:30:25 AM »
 :-X
I would You could drop the gear chain out unless you are thread cutting or using the power feed.
Edit: I didn't want anyone thinking I would have a Chinese machine in my workshop  :lolb:
« Last Edit: February 09, 2020, 08:33:35 AM by Jo »
Offline Bluechip
  • Derbyshire
Re: Gloat
« Reply #23 on: February 09, 2020, 08:42:07 AM »
Will do just that.  :ThumbsUp:
Not likely to screwcut on it anyway.
In the last 15 years or so only ever once screwcut a metric thread on the Myford. Lots of inch threads though ...
Offline Bluechip
  • Derbyshire
Re: Back to Gloat
« Reply #24 on: February 09, 2020, 08:44:22 AM »
Funny ....  :headscratch:  I thought I once saw one in there  ...... little  red thingy ......... Nah! Must have been hallucinating.
Re: Gloat
« Reply #25 on: February 09, 2020, 09:33:01 AM »
 :o
The Red Devil bench grinder was made in China  :facepalm:
Re: Gloat
« Reply #26 on: February 09, 2020, 10:13:09 AM »
Dave three things to get quiet gears for power feed as well as screwcutting, I leave my gear train engaged all the time and get minimal noise from it, just use the front lever to put it into neutral when not needed.
1. Start from the gearbox input end of the banjo and with some strips of copy paper gap each of the gear pairs, just put a strip into the gears and turn them so the paper takes on a zig-zag then nip up the pivot. Do the same when you swing the assembled banjo back against the fixed 40T on the spindle. This sets the backlash.
2. Spacing washers. There are 2 washers that space the gear pairs away from the banjo they are slightly different thicknesses. The thick washer goes with the pair that have the smaller gear towards the banjo, the thin washer goes with the pair that have the larger washer towards the banjo. get it wrong and the edges of the gears can rub giving  a ringing sound.
3. Similar to above there is a small amount of left to right movement of the banjo where it pivots around the gearbox input, this can also be used to stop the sides of the gears touching
Offline Bluechip
  • Derbyshire
Re: Gloat
« Reply #27 on: April 04, 2020, 03:31:22 PM »
Got the WM18 up on it's perch.
All on my own .... there's a lot of things we are having to do all on our own these days ......  :'(
After I've staunched the the blood seeping from various holes and had a Rum & Coffee I just have the cables to tidy up and we are away ...  :ThumbsUp:
Pallet converted to firewood  for  Jo ....  :)
Re: Gloat
« Reply #28 on: April 04, 2020, 03:33:35 PM »
I thought it was a lathe last time you showed it to us Dave :noidea:
Offline Bluechip
  • Derbyshire
Re: Gloat
« Reply #29 on: April 04, 2020, 03:43:07 PM »
Lathe still there  :)
Attempt at group shot ... can't get further away.
I am a poor pauper of modest means. I have to make do with a rude hovel to house my machines.  ............ Unlike some folk ....  :lolb:
