Mike.
I look forward to the build....I think I have a set of those castings somewhere so will pay attention!
Just interested to see if the kiln can melt some metal and if it could be used with printed patterns.
I'm really keen on SLA print to investment casting which I think creates new possibilities. The right print resin becomes the "wax" master; Its taken over in jewelry making. The resolution of the SLA print is so high, and with investment casting complications are so easily dealt with (no cores etc).
The same can be done with printable wax ina filament print, but the detail of SLA is compelling. The material shrinking probably makes it impractical, but from a resolution standpoint, its holds fine details so well you could cast in the threads.
I have everything but the SLA printer....the fancy ones are still kind of expensive but I'm almost there, I need to let the updated version of "Reason" run a few trillion more computations.....
