Author Topic: A Tandem Compound Mill Engine  (Read 3024 times)
Offline Ramon
  • Suffolk in the UK
Re: A Tandem Compound Mill Engine
« Reply #60 on: February 21, 2020, 04:56:59 PM »
Nice work on that governor pulley David :ThumbsUp:
It was the likely hood of not being able to tighten the nuts inside the eccentric cut-out that was the real deciding factor for making them one piece. As someone pointed out on mine after fitting dummy bolts, once in situ they can hardly be seen anyway  ::)
Plus one on doing the straps first too :)
Regards - Tug
Offline deltatango
« Reply #61 on: March 09, 2020, 11:03:50 AM »
Thanks Tug, it's good to have you following along.
This reply has taken longer than I'd expected, a week away in South Australia and a mini CNC machine project have got in the way. I'm back in the workshop now but with two projects on the go together. On the mill engine front the crank and crank pin were the next bits. The crank starting out as the end of a bit of flat steel bar that came in the kit for the Wyvern (think it was intended to become the con rod but I fabricated that instead of carving from the solid):
After the holes were drilled and reamed the blank was roughed out using the bandsaw:
A bit of tool making followed to make a centering pin to locate the part on the rotary table and to drill and thread a hole in the RT adaptor plate for a clamp screw:
the stepper motor drive for the RT handled the rounding of the ends and I'm pleased with the finish from a 10 mm carbide end mill:
The same tool cleaned up the flat sides as well:
The pin was turned on the end of a scrap shaft from a washing machine gearbox, which I hope will be a steel with good wear properties, and then the oil holes drilled:
The two bits won't be fixed together for a long time yet but this is what they'll look like:
The two 8BA threaded holes are for fixing the bit that catches oil from the lubricator.
I feel the need to get the flywheel and crankshaft bits spinning so the main bearings and supporting cast iron will be next.
David
Don't die wondering!
Offline J.L.
« Reply #62 on: March 27, 2020, 08:23:57 PM »
Beautiful photography as well as superb machining.  :ThumbsUp:
Offline deltatango
« Reply #63 on: March 27, 2020, 11:18:25 PM »
Thanks John, it's good to hear from you again.
Right now I'm trying to finish off another project that has been occupying desk and bench space for too long, I'll get back to the Compound "real soon now". The other project is a miniature CNC mill based on a scrapped microscope; this provided cross-roller linear rails for the XYZ guides and a stiff frame. Adding steppers and lead screws etc didn't look too hard but it would probably have been quicker to start over, ah well...
David
