Note: My 3D printer requires designs to be laid out in the XY Plane in metric dimensions. I drew a 2D half-sketch of the bowling pin in the ZX Plane so when rotated about the Z axis the 3D bowling pin would be sitting on the XY Plane. The sketch was a 15 point spline, 2 circles and 2 lines. There’s a hole in the bottom of the pin.Exported and saved as STL file (in imperial). This is for CNC.Modified CubifyDesign Properties to metric.Exported and saved as STL file (in metric). This is for the 3D printer.3D printed (just to see). 58+ minute print time.
So what breakout board did you decide to go with? Or can you run the 540 directly from the smooth stepper?
Hi ZeeI had never looked at the 540, but it appears that it also serves as a breakout board. Without the interface of the break out board I don't think that you could wire motors, limit switches, etc directly to your SS board. My system uses separate Gecko drives so I needed an interface (PMDX125) between the SS and motor drives, your 540 accomplishes this. The PMDX board also gives me spindle control through a small daughter board.Attached is a photo of my servo amp box you can see the PMDX board with the SS mounted on it in the upper right hand corner of the box, the blue Gecko 320X servo amps are on the far right.Dave
