Hi Modelenginemaker,
After sneaking around for a long time without posting anything, I thought I might also share something.
I have posted this one somewhere else a while ago, so just ignore it if you have seen it already.
I have been working on this one for over 4 years now and it finally came to a successful end...
After researching numerous builds from other people and combining things together I eventually distilled my own engine design.
I wanted to work in the metric system and also wanted to adjust the size of the model and its complexity to my own demands. As most of these models serve only the purpose of pleasing the builder as they come "alive" I also wanted a design that would suit my own aesthetic ideas of how it should look like.
I opted for the looks of an early 20th century motorcycle single. After about 3 years of irregular work, I had my first test run which was a failure. The engine would not run continuously even though I had a few puffs. I re-evaluated a couple of things and decided to change the cams to milder timing characteristics, enlarge the flywheel, improve the valves and their sealing and also improve the sealing of the carburetor. This work took me about 5 more months to complete.
But the second try was an immediate success. The engine now starts really easily and runs quite well. The RPM range is quite narrow though - it idles at around 950 RPM and reaches its maximum at 1800 RPM.
It also needs some time to rev up and down this range which is due to the large flywheel. I am also pleased with the way it sounds which was also one of my goals.
Some engine details:
- the square design of 25 mm stroke to 25 mm bore
- spark plug ignition using NGK CM-6
- home-brewed stand-alone ignition module using automobile coil
- O.S. 1A carburetor
- running on Coleman fuel mixed with 5% 2-stroke oil
- splash lubrication
A short video of the running engine:
Till next time. Cheers,
Branislav
