Is yours a morse taper, or something like that? Any defects in the surface, grit or dings, will keep it from gripping. You should be able to put it in, with a little twist, and feel it grab. Look for shiny spots, feel for bumps on the taper.
Looking at the pictures again, looks like the surface on the inside of the tailstock is all chewed, needs to be smooth and shiny. What kind of lathe?
Quote from: crueby on January 08, 2020, 11:25:17 PMIs yours a morse taper, or something like that? Any defects in the surface, grit or dings, will keep it from gripping. You should be able to put it in, with a little twist, and feel it grab. Look for shiny spots, feel for bumps on the taper. When I insert the chuck I always twist it to ensure it is snug and tight. Still, sometimes it lets go and the chuck spins.Quote from: crueby on January 08, 2020, 11:27:13 PMLooking at the pictures again, looks like the surface on the inside of the tailstock is all chewed, needs to be smooth and shiny. What kind of lathe?It's a Precision Mathews (PM 1030V). Indeed, it is chewed. The question is, can I fix it or do I need to get a new tailstock (which I suspect is problematic in and of itself.Thanks.I don't doubt I did something wrong but I don't know what. I generally clean the chuck's taper as well as the innards of the tailstock.My suspicion is that, regardless of how clean it is, if the chuck spins then galling may make it worse.Perhaps it wouldn't have gotten so bad had I taken care of it (don't know how) the first time it happened.I've had sessions where it happened three times in a row...so I think it just got worse.
Tapers need to be clean and dry, and are usually assembled by a quick linear motion to seat them, (not twisting).
