Cylinders are looking great Chris! Glad the stacked C-weights are working out. Saves on earthquake insurance when your turnings are balanced better! The lug sculpting looks good. When it was ticking on the bed of the lathe, did you calculate the amount to remove, or just eyeball it? BAD PUN ALERT WHOOOOT! WHOOOOT! WHOOOOT! BAD PUN ALERT WHOOOOT! WHOOOOT! WHOOOOT! BAD PUN ALERT WHOOOOT! WHOOOOT! WHOOOOT! BAD PUN ALERT WHOOOOT! WHOOOOT! WHOOOOT! You could have used a lug orithm for the calculation..........
Watching that assembly spinning around on your Sherline lathe must of been quite a site! Coming along nicely, Chris. Jim
It’s truly enjoyable watching these cylinder “castings” emerge from a block of 9f metal.
The elf yodeling with kazoo accompanying it all night was a little rough, but I deserved it!
Re Alvin - I consider myself warned! MUCH better quality puns ahead. I think you may have been a torture system designer in a previous incarnation......although you didn't mention Italian opera sung in Mandarin Chinese at 2x speed yet!
Are there holes in the fixture to allow boring all the way through?
