Quote from: steam guy willy on February 15, 2020, 01:53:56 AMHi Chris, do your little helpers have their own little pots of swarfega ?!!! WillyI've learned not to ask...!Perhaps you could make a beam engine and leave the Iron Maidens lying around ?!!! I haven't had any trouble from them recently !!!
What? Plenty of room! Why I must measure several inches across on the monitor... -Doug
...the crosshead guide looks completely different than any of the other plans or photos I have seen, with a squared slot in the guide rather than the usual arced surface. Is this just a partial view of the parts, or did they make the guiide this way at some point?
The piston rod lower end was most likely one piece (or welded) to the crosshead, ...
you know this rate of progress is really making some of us look bad,, but I am learning and planning things from it all
