The inside of the Kiln was cooler than my workshop when I started which proved the fire bricks inside it are good insulators. It also means that even when the temperature reaches the correct temperature and the control box turns off the power the temperature is going to continue to rise before it starts to drop back again. You can see when it is heating by the neon on the right
