Author Topic: Stuart oscillator  (Read 2666 times)
Offline samc88
Stuart oscillator
« on: December 16, 2019, 09:27:51 PM »
Made a start on my Stuart oscillator the other night, thought I'd start with the cylinder which came out pretty well, just have to drill the steam ports and lap the port face
Sent from my G3121 using Tapatalk
Re: Stuart oscillator
« Reply #1 on: December 16, 2019, 09:31:55 PM »
Is this the cute little single cylinder Oscillator that Stuart do Sam?
I love how the cylinder is designed to nicely be held in a three jaw chuck for boring it. Hope you remembered to take note of which end you bored from  ;)
Offline samc88
« Reply #2 on: December 16, 2019, 09:35:42 PM »
Yes, that's the one. I did it in the four jaw, can easily tell which way I bored it as one end was faced off a little more central to the bore than the other one. Credit to Stuart the casting was already pretty square, just needed a light cleanup before machining down to size
Been doing a few tooling projects and other stuff on the lathe and fancied a small engine project and this looks like a nice little kit to get started
Offline bwal
« Reply #3 on: December 18, 2019, 08:27:46 PM »
Hi,
I did one last year. If I remember correctly when you do the cylinder covers the PCD won't match up with the extruded "grooves" in the cylinder. I had to mill out the grooves some.
Ben
Offline samc88
« Reply #4 on: December 18, 2019, 08:30:23 PM »
Hi,
Ben
Thanks Ben, they were going to be the next task after finishing the cylinder. I think I might use my transfer punches from work down the grooves to mark the hole positions when I get to that point. Not seen many build threads on these engines
Offline bwal
« Reply #5 on: December 19, 2019, 10:30:08 PM »
HI,
I remember at the time it really annoyed me as it was the first time I'd used the PCD function on the DRO on my mill. I think Jo had the same problem.
Ben.
« Reply #6 on: December 20, 2019, 03:29:46 PM »
Yes well remembered Ben I did. I got round it by using a needle file to open up the slots slightly  ;) .
My build of the Stuart twin starts here: http://www.modelenginemaker.com/index.php/topic,9007.msg200618.html#msg200618
Offline samc88
« Reply #7 on: December 21, 2019, 04:17:45 PM »
Not done much, hoping to make some proper progress tomorrow. I did start on the cylinder head this afternoon
Offline samc88
« Reply #8 on: December 29, 2019, 08:48:16 PM »
Bit more done, got the top cover finished apart from drilling the holes but have a plan for them. I made a mandrel out of a piece of pipe that I could put the cut off piece into to face it off. I didn't do the top register to the drawing as it's just decorative so just did it by eye until I was happy with how it looks
Offline samc88
« Reply #9 on: December 29, 2019, 09:16:21 PM »
Ran a 2.6mm drill down the grooves of the cylinder for 7ba clearance then used a dab of glue to hold the cylinder head to the cylinder. Stood it on the cylinder cover and drilled down through the grooves to spot the hole positions
Offline samc88
« Reply #10 on: December 31, 2019, 03:56:53 PM »
Bottom cover now done
Offline propforward
  • MN, USA
« Reply #11 on: December 31, 2019, 03:59:53 PM »
Nice - coming on very well. Looks great - excellent fit achieved there.
Forging ahead regardless.
« Reply #12 on: December 31, 2019, 04:13:00 PM »
Looking good, nice finish on the parts too.
« Reply #13 on: December 31, 2019, 05:26:52 PM »
Nice. Are you going to fit any gaskets under the covers?
Offline samc88
« Reply #14 on: December 31, 2019, 05:28:16 PM »
Thanks. I will do when it comes to final assembly, just put them together so I don't lose anything
Next job I think will be the piston assembly
