JonThis is very impressive work, are you using original drawings or the real thing for reference. Do you still intend to make castings available to buy?Mike
Hi Steamer, I agree it doesn't give much engagement but working back from the cam pulley size restriction it's the biggest I can get on the crank.The bouland engine below is 1/3rd scale and looks like its using a 12.7mm single belt driving both cam shafts from a similar small crank pulley.Jon
My usual starting point for actual designs (when I am not winging it) is: https://sdp-si.com/D820/PDFS/Technical-Section.pdf 6 teeth seems to be minimum wrap. Belts that are wider than diameter of pulley give tracking issues. Short belts also give tracking issues. Roundinsh profiles have less cogging action and don't tend to ride up the pulley as much. But their profiles are generally proprietary although the sdp-si manual conveniently gives the related patent numbers for further educaation. They can apparently be approximated using ball nose end mills and cnc. :-)One suggestion might be to gear drive from crank to the large central pulley, then single belt from there around al the cams. Outside idlers are preferred over ones riding on teeth.
