Author Topic: Micro wing nuts  (Read 2721 times)
Offline Dan Rowe
  • Dripping Springs TX USA
Micro wing nuts
« on: December 06, 2019, 10:47:35 PM »
The old Bell System crimper tools are very useful to forge shapes. There are two tools the System D tool has a single hole and the System B tool has two smaller holes.
I took a 1/8" brass rod and smashed wings on it. I flipped the stock a few times so both wings are the same thickness. If no flip is made the inside wing will be thinner than the outside wing.
Here is a wordless photo showing the process to make 0-80 wing nuts.
Cheers Dan
« Last Edit: December 06, 2019, 11:05:20 PM by Dan Rowe »
ShaylocoDan
Re: Micro wing nuts
« Reply #1 on: December 06, 2019, 11:27:13 PM »
Great trick! Did you need to anneal the rod?
Offline Dan Rowe
Re: Micro wing nuts
« Reply #2 on: December 06, 2019, 11:32:03 PM »
No I just smashed it. I think I will anneal the rod the next time before I bend the wings out slightly to take the stress out.
Dan
ShaylocoDan
Re: Micro wing nuts
« Reply #3 on: December 07, 2019, 01:20:57 AM »
That is pretty cool, I have a small project on the bench that requires one 0-80 wing nut. I was thinking about modeling it and machining it on the CNC.
I think now I may check out my selection of crimpers!
Re: Micro wing nuts
« Reply #4 on: December 07, 2019, 07:36:56 AM »
Very neat  :ThumbsUp:  :ThumbsUp:  :wine1:
Re: Micro wing nuts
« Reply #5 on: December 07, 2019, 10:03:39 AM »
That is brilliant Dan.......however you must anneal the 3 or 4 times.......cherry red, then air cool each time....otherwise the potential exists for them to split & shear  :hammerbash: at the slightest tension
Derek
Offline Florian Eberhard
Re: Micro wing nuts
« Reply #6 on: December 07, 2019, 11:25:19 AM »
Thats a clever method!
Why not "forge" it? Heat up the rod and then squeeze it while its hot. That should be even easier to form the brass.
Cheers Florian
Offline Dan Rowe
Re: Micro wing nuts
« Reply #7 on: December 08, 2019, 08:17:11 PM »
Thanks for the feedback guys.
I decided to try hot forging one from 302 SS rod. The rod will not stay red hot long enough to get the jaws of the tool set but it was still hot so easier than cold.
Here is the finished SS 0-80 wingnut.
Cheers Dan
ShaylocoDan
Re: Micro wing nuts
« Reply #8 on: December 08, 2019, 08:21:56 PM »
I'm intrigued.  What sort of project requires a 0-80 wing nut?  Inquiring minds want to know...
Re: Micro wing nuts
« Reply #9 on: December 09, 2019, 12:40:53 AM »
I must admit that unlike George who revels in building near microscopic things. I would more likely scale it up to avoid that small of a wingnut. Good to know it can be done if necessary though.
Offline Dan Rowe
Re: Micro wing nuts
« Reply #10 on: December 09, 2019, 12:54:02 AM »
Art,
I was actually making thin nuts with wings to hold in wood from a section that looked like the first piece in the photo. I saw that with a bit of machine work it could make a micro wing nut so I just had to give it a go.
Cheers Dan
ShaylocoDan
