.......I'm having no luck finding Chris's Stanley Steamer project. I know he promised so it must be here somewhere. If anyone can point me to it...I'd appreciate it. (He forgets I'm not that far away...and I personally know some of his elves.)
I was thinking a person could cut segments out of 1/4" sheet and then laminate two thicknesses together, staggering the joints and pinning them with brass rod. Much like a wooden wheel would be built. Pockets for the spokes could even be milled into the segments before assembly. In fact the hub and spokes could be assembled and then the rim assembled over the spokes. Jim
Quote from: Flyboy Jim on November 18, 2019, 06:06:34 PMI was thinking a person could cut segments out of 1/4" sheet and then laminate two thicknesses together, staggering the joints and pinning them with brass rod. Much like a wooden wheel would be built. Pockets for the spokes could even be milled into the segments before assembly. In fact the hub and spokes could be assembled and then the rim assembled over the spokes. JimSounds like that would work well. Good use for the rotary table.
FWIW, candelabras have more than one light. That's a candlestick.
How big a piece of brass are you talking about for the spinning wheel?
For adjusting the height, how about a threaded rod under the platform, raise with a nut.
what software are you using?
You plan on building another?
I'm not a fan of keeping my data in the cloud.
I've been using Fusion for several years, does everything I need (and a lot more). The animation of parts is something they are still developing, they can do rotating/sliding type movements where you pick the centers, so it can do eccentrics, but it will not follow a non-round cam. Also will not let you have chain go around a sprocket then off to the next sprocket. That may change in future releases. I like it a lot, but I have no experience with other CAD products to compare it to.
