Author Topic: What's in my Shed  (Read 8464 times)
What's in my Shed
« on: November 17, 2019, 11:39:35 AM »
I was asked the other day in the Midget thread about my workshop so now that the top secret new products have been hidden away I was able to take a few snaps, did I mention that one of the perks of testing and doing reviews is the items seldom have to go back to the supplier :naughty:
I have an 8 x 16 shed, insulated with 50mm PU insulation in the walls and ceiling then lined with faced OSB. I made a new door to replace the flimsy pair that were on the end and changed the basic windows to double glazzed UPVC. Sorry the large Bonsai are not looking their best this time of year.
As you enter to the right is a bench that does not get used that much, meant for grinding and welding and other similar dirty tasks, since getting the Femi bandsaw that tends to live at one end and the fish food at the other. The Parrot vice is quite handy being able to swivel and it can also be mounted on it's side. Few odd draws below but not much engineering related stuff in those.
Moving around the next section of bench has a Tormek Grinder, bench Grinder, small belt sander and bench drill which does not do a lot of actual drilling these days being used more for honing, wire brush or polishing etc. Not Much in the way of model engineering items in the draws above but a few larger M6 and over fixings, springs etc.
Further along this wall was a nice bit of clear bench where a model being worked on could be kept or drawing laid out but lately it has been occupied by the Sieg SX2.7 from ARC that I have been using for some magazine articles that they sponsor. Smaller draws below have steel stock in but most of the larger are again not filled with ME stuff.
This half of the shed is where most of the action takes place, starting with the Warco WM280VF which I have had for about 10 years now (yes they will last that long ;) ) few frequently used tools behind and sets of metric and imperial drill boxes with some common size stubb length ones to the right.
I replaced the flat metal panel between the cabinets two cupboards with some draws on full extension runners to keep lathe tooling in.
To the left of the lathe across the end wall is the bench with my vice and saws & files stored above. To the right is the modern version of the wooden engineers chest and beyond that lathe chucks in the corner. The opposite corner is taken up by the mill.
Draws under this bench which are again on FE slides have non ferrous metals to the right and odds and ends to the left.
The Sieg X3 mill sits quite nicely across the corner with a few bits related to it up on the wall and tooling like collets, cutters and spindle tooling easily to hand in the draws below. I've had this since 2007 and apart from a couple of belts, one set of brushes and an LED light it has performed well. I have added a DRO and there is also a X-axis powerfeed left from testing and also a spindle speed readout.
The front wall with the view is taken up with a final run of bench where i can sit and fiddle with engines, mark out, etc and the left hand end is where most of the engine stand when being run, few odd screwdrivers in a rack behind.
Marking out and measuring tools in the draws below and the metal ones have things like taps & dies, reamers, drills and so on. You may have gathered by now that I tend to keep most of my things in draws, I like it that way as you can keep the swarf and fine cast iron dust off them so you don't get black hands when you pick up a tool that has not been used for a while.
I have also recently got a CNC mill in the form of a Sieg KX-3 but had to put that in the garage, it may get moved back into the shed when the SX2.7 goes back but more than likely it will stay where it is.
So that's about it, sorry there are not vast amounts of tooling or multiple ex industrial machines to see but I find that is all I need to keep up a regular flow of completed and running engines and that the far eastern equipment is upto the job but as they say the most important Knob in the workshop is the one doing the actual work ;)
PS. Before you ask, yes my workshop is usually that tidy.
Re: What's in my Shed
« Reply #1 on: November 17, 2019, 12:10:50 PM »
I don't know why you have such a chip on your shoulder about using and owning Chinese machines/tooling they are perfectly adequate for home use. But I think the average person first setting out to make model engines will think you have vast amounts of tooling in comparison with what they have  ::)
P.S. Surus noted that you don't have any casting sets in your workshop.  (Not showing them was a good move as he doesn't want to visit you  ;) )
Offline pgp001
  • West Yorkshire - UK
« Reply #2 on: November 17, 2019, 12:18:23 PM »
Nice to see other peoples workshop layouts Jason, very efficient use of space.
It differs from mine mainly due to the fact that my (mainly not Chinese by the way) machines are almost all floor standing, so that seriously limits the available space for benches and drawers at ground level. I have a purpose made insulated wood shed which is 16' x 12' and it is absolutely crammed full. So like you I have be a tidy worker and not let junk get in the way all the time.
I will try and put some photo's on at some point.
Phil
« Reply #3 on: November 17, 2019, 01:15:57 PM »
Thanks for the tour of the shed Jason. Very neat and organized and obviously up to the tasks you ask of it.
« Reply #4 on: November 17, 2019, 01:59:02 PM »
That's a good neat workshop  :ThumbsUp:  :ThumbsUp:  The number of machines will always expand to fill the available space even if you aren't directly responsible for their arrival  :)  :)  :)
Offline Flyboy Jim
  • Independence, Oregon
« Reply #5 on: November 17, 2019, 02:03:59 PM »
Very nicely set up workshop Jason. Thank you for showing us around.
Sherline 4400 Lathe
Sherline 5400 Mill
Offline Johnmcc69
  • Erie Pa., USA
« Reply #6 on: November 17, 2019, 02:27:18 PM »
Very nice layout Jason! I really like the natural lighting! It looks like a great place to spend (lots of) time.
 Computer? Does it live in the house or do you use a laptop?
(I'm not saying a computer is a workshop requirement, I'm just curious.)
 Thanks for the tour!
Online RayW
« Reply #7 on: November 17, 2019, 02:41:39 PM »
Very nice setup you have there Jason. Makes my little workshop look like a broom cupboard in comparison.
Ray
Offline mike mott
  • Alberta Canada
« Reply #8 on: November 17, 2019, 03:02:49 PM »
Thanks for the tour of your workshop Jason, I really like the way you have organized your tools in the drawers, it is nice to keep the big wide shelf bench clean. it is something that i have to constantly remind myself of too.
« Reply #9 on: November 17, 2019, 04:16:03 PM »
Nice Shop Jason, thanks for the look around!
« Reply #10 on: November 17, 2019, 06:19:13 PM »
Thanks for the shop tour, Jason.  Very nicely laid out, and ever so tidy!  My shop is seldom so tidy.  Certainly something for me to strive for!
Offline jadge
  • Cambridge, UK
« Reply #11 on: November 18, 2019, 09:14:25 AM »
So that's about it, sorry there are not vast amounts of tooling or multiple ex industrial machines...........
Oh dear, I'd better keep quiet.  :embarassed:
It's a mystery how I manage to produce anything using rather old secondhand ex-industrial machines. However, sometimes size matters, or so I'm told:
Workshop tidiness varies. In the motor racing machine shops I've been to you could eat your dinner off the floor. On the other hand I've visited a commercial machine shop where you wouldn't let your dog go to the toilet. But they did have industrial machine tools that were bigger than Jason's shed.   :)
Andrew
« Reply #12 on: November 18, 2019, 12:37:15 PM »
Thanks for the interest
Jo, as it is a workshop and not a storage room your little friend won't find any surplus castings in there. Did you notice that 3 of the 4 engines in there are from casting sets, I must be slipping ;)
John, I don't have a computer in the shed. There is a reconditioned tower hiding behind the CNC mill hidden by the bit of bubble wrap I put over it when not in use. Otherwise design and CAM get done in the house.
Andrew I suppose it depends on what we get upto in our workshops, a 2" traction engine or large hit and miss engine is about my limit and the sort of size I'm happy with, if I were doing something larger or had more of a need for large metal removal rates then a more substantial machine would be needed which would take me out of the bench top range. Though I can still manage to work on some large items. I do keep looking at that Colt that Home & Workshop have had on sale for a long time which would be more the sort of thing I would go for rather than a toolroom lathe such as a Hardinge.
I do like to tidy the workshop regularly, usually gets done on a Sunday afternoon just before I pack up for the weekend. That way if I do need to use the workshop for anything in the week I can be sure of having an empty bench and all tools where I know their location. I'm much the same in the woodwork shop where the most used tools are the bench brush and broom.
Offline Allen Smithee
  • Mordor, Middle Earth
« Reply #13 on: November 18, 2019, 01:06:34 PM »
However, sometimes size matters, or so I'm told.
I always used to think size wasn't important, but then all my wallpaper fell off.
AS
Offline ShopShoe
  • Central Iowa, Central USA
« Reply #14 on: November 18, 2019, 01:37:41 PM »
Very Nice use of space. I like drawers too, under benchtop machine tools.
It is especially nice that you seem to keep everything clean and organized, even though you allude to a lot of non-model work.  I find that is what I am always fighting: Evrything is neat in the machining department, then I have to take a lawnmower apart and leave it that way until I acquire the repair parts. Not to mention the occasional woodworking which makes sawdust and then needs isolation for finish to dry and cure.
--ShopShoe
